Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 01-25-2011, 01:43 AM
grc grc is offline
grc is on a distinguished road
Old Bronx CNC Press Brake
Working on a old Bronx 25-15-CNC/VDU press brake and I cannot get the machine constants to store. When trying to save these I get a "STORE FULL" message even though there are none stored. Programs and reference positions store fine. I disconnected the battery to clear the RAM and it still comes up with the same full message. One other thing there is a led on the CPU board that says "MEM PROT" and it is on, not sure what that means.
Any help would be greatly appreciatted.
Geoff
Old 01-29-2011, 10:05 AM
rjahr is on a distinguished road
Most likely that is a memory protect button... It's there so you cannot change anything unless it's off... You should have a memory protect key on the faceboard somewhere you need to turn that off in order to change your values.
Old 01-29-2011, 11:19 AM
grc grc is offline
Thanks, I found a guy in England that knew that machine well and the fix was" From the menu press 4 then 2 then LM the screen will show fault this should clear the memory but make a note of the constants and tool references as you may loose them,you will loose all programs"
Looking to buy Used Press Brake magma-joe Bending, Forging,Extrusion... 5 01-16-2012 02:05 PM
Need Help!- Press Brake BROWNI Bending, Forging,Extrusion... 1 01-08-2011 09:12 AM
Need Help!- Selecting Press for home shop press brake tikka308 Bending, Forging,Extrusion... 0 12-28-2009 10:51 PM
Press Brake davesnd CamSoft Products 0 12-02-2009 12:11 AM
NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? dsmdude Bending, Forging,Extrusion... 6 04-13-2007 04:01 PM
