| Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here. |
I need some technical advice/info regarding a project I'm working on. This is a self-built electromagnetic sheetmetal bender (ala MagnaBend or ElectraBrake). What I need help with is figuring out how to wire in my bar type electromagnets using the controller/powersource... Do I wire in series, parallel, series-parallel? For your contributions, I will include my .pdf files of all the mechanical components, a source list for the electromagnets & controller/powersource, and a build sheet to make your own ![]() Of course, I need help to complete this project first, so I can work out the bugs and supply correct, functional build data to the community. |
| Hi 307startup If you want to build something like a Magnabend or ElectraBrake your best bet is to go to the following link:- Magnabend Electro-Magnetic Sheet Metal Bending Machine This site is maintained by the gentleman that invented the Magnabend He has generously put up all the information you would possibly need to build an electromagnetic brake similar to the Magnabend. There is lots to read and the information seems to be very complete. Regards, Jayson. Edit: Sorry all I did not notice the original post date. Anyway hopefully the link will help someone
__________________ Quick... catch all the smoke so I can stuff it back in. |
| Didn't knew the magnabend, very nice machine. [edit] if making the electromagnet looks difficult you could use a couple of electromagnetic door locks, there provide hundreds of pounds pressure Pablo
__________________ ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ● |
| My CNC Bender Build | supahonkey | Bending, Forging,Extrusion... | 115 | 03-15-2010 06:17 PM |
| Mach 3 Tube Bender Build - Implementing a strain gage | supahonkey | Machines running Mach Software | 2 | 02-28-2010 08:53 AM |
| Need Help!- DIY Electromagnetic Chuck Controller | parametric.ms | Work Fixtures and Hold-Down Solutions | 0 | 04-07-2009 01:42 PM |
| Looking 4 someone that would like to build a mini cnc tube/pipe bender for 3/8 | dbtoutfit | Bending, Forging,Extrusion... | 27 | 10-18-2006 09:45 PM |
| ElectroMagnetic Drawbar? | DennisCNC | Mechanical Calculations/Engineering Design | 17 | 01-09-2006 11:01 PM |
