Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 11-16-2010, 04:44 PM
R.DesJardin's Avatar
R.DesJardin is on a distinguished road
Low cost sheet bend software
I'm looking for a cheap software ($100 or less) for calcualting bend radius'/layout lengths for thin plate layout. Just something simple is all I need only 1 or 2 bends per part is typical. 3/16" plate thickness is standard up to 1/4".
Old 11-18-2010, 04:05 PM
jpgdesigns is on a distinguished road
no need for software if you are just talking about a few thicknesses... have the shop bend up some sample pieces of know flat size and make a chart of the final bent dimensions...
should be a lot less than 100 bucks and you will know exactly what you will get with the press tooling you have...
Old 12-06-2010, 04:17 PM
Bend Tech SM
Bend Tech SM is a new sheet metal/plate bending software that just came out. $285.00 US. Not the $100 I dreamed of but well worth the cost. I bought it already, first day it was out actually. Bend Tech has a great reputation with their tube bending software. Not really any info on the website for SM yet as it was just released Dec. 1st, I had a little bird tell me about it.
Bend-Tech Home
Need Help!- South Bend Magnaturn 1218 software installer Azor Controller & Computer Solutions 1 06-07-2010 10:58 AM
low cost 4 axis maching software sgman General CAM Discussion 4 03-28-2009 06:12 PM
Is there a such cnc machine that will bend sheet metal any way you want? slashmaster General Metal Working Machines 18 03-23-2009 05:44 AM
Need Help!- Easy Development Sheet Metal software Khalid Bending, Forging,Extrusion... 0 02-23-2008 02:43 AM
Need AL or Steel bending die to bend sheet metal firearm receiver mike_r Employment Opportunity 1 06-11-2007 08:03 AM
