Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
  #25   Ban this user!
Old 03-07-2006, 11:06 AM
dbtoutfit is on a distinguished road
Talking
  #26   Ban this user!
Old 03-07-2006, 01:20 PM
wizard is on a distinguished road
My experience was with die casting a long time ago. That process would not work for this part!
Depending on what your needs are I would imagine that you could do a sand casting with a core. The core would be comples and probably fragile for such a smal part. The core molds would also be complex. There would be alot of work going into this before you even had a part.
Consider a lost wax process also which might be a bit easier.
A hard mold would be very complex if this is a low production rate item. It might be useful to consider though.
Dave
  #27   Ban this user!
Old 07-07-2011, 01:27 AM
frequent flyer is on a distinguished road
bending tight bends in tubing
This is what I use to make all types of headers for RC aircraft. It works well for Alum tube but you must anneal the tubing first. For Stainless steel headers it takes more power and I use a hydraulic bender with custom made dies . What ever you need a mandrel in side the tube to prevent it from collapsing.
ID:	137917   Click image for larger version
ID:	137918   Click image for larger version
ID:	137919   Click image for larger version
ID:	137921   Click image for larger version
  #28   Ban this user!
Old 07-07-2011, 02:23 AM
Would you mind explaining a little more about the SS tubing?
I really wanted to go this route but was concerned about weight.
What size tubing do you use? Wall thickness? Is there a specific type?
Do you have to Tig SS or can it be Brazed?
Any general knowledge on the subject would be nice.
Do's
Dont's
Etc
Very Nice tools BTW, are those for sell to the US?
Thx
Eric
Theres a good side to every bad side, you just have to look around the corner.
RFQ - Small production run of aluminum part - European Machine Shops Only Please jayd Employment Opportunity 2 04-30-2005 05:34 AM
mandrel bending MBG Bending, Forging,Extrusion... 4 03-22-2005 01:29 PM
contouring aluminum with small bit corpse Benchtop Machines 6 09-14-2004 01:11 PM
Bending small aluminum rod Twmaster Bending, Forging,Extrusion... 9 08-06-2004 07:50 PM
Bending wakeboard Bending, Forging,Extrusion... 7 01-18-2004 05:58 PM
