Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 10-05-2010, 05:45 AM
Andriy77 is on a distinguished road
press brake can't find reference point
We have problem. Press brake GASPARINI x-press 100 can't find reference point only on Y. Beam goes through limit switches without any effect. Switches passes signal to the electrical box and laser box.
Old 10-17-2010, 12:16 PM
SYMATECH is on a distinguished road
hi,
what cnc is built on your machine and is it a servo hydraulic machine or a torsion pressbrake ?
you said the switches passes the signal to the electrical box, maybe you have an relais in the control cabinet which is not working or have contact problems, so that the cnc get no signal to switch off the valves and stop the upper movement... but its just a guess from side...
if you have a servo hydraulic machine, you have 2 measuring scales on y1 and y2... maybe you can check it...
thats all for now...
regards
Need Help!- Selecting Press for home shop press brake tikka308 Bending, Forging,Extrusion... 0 12-28-2009 10:51 PM
Need Help!- Lost reference point Finnur General Metal Working Machines 6 11-23-2009 03:50 PM
Problem- G30(reference point return) Reg wharton Daewoo/Doosan 2 06-13-2008 05:32 AM
NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? dsmdude Bending, Forging,Extrusion... 6 04-13-2007 04:01 PM
Return through reference point? RBrandes Haas Mills 3 12-02-2005 09:49 AM
