| Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here. |
| hello, first of all, what cnc is built on the machine ? well, you get started the main pump ? have you check the emergency buttons, maybe one is pressed... check also the fuses in the control cabinet... if you have a cnc on the machine, you get any error message or any other warning message ? thats all for now... regards |
| Ok, we have an Amass at work just the same prob happens all the time. With ours we discovered there was a short in the wires from control box to circuit board. As the control box can be adjusted to the ops needs it develops short in wires due to movement. Check there. If not then check your files through bendcad if you have it, files can cause errors unknown if written wrong or have incorrect punch and die info. |
| Need Help!- Need Advice on Purchasing Amada Punch Press | robd19 | General Metal Working Machines | 1 | 08-31-2010 11:28 AM |
| Need Help!- Amada brake press controller nc9 r | maplesiport | Controller & Computer Solutions | 0 | 07-15-2010 05:32 PM |
| Need Help!- Selecting Press for home shop press brake | tikka308 | Bending, Forging,Extrusion... | 0 | 12-28-2009 10:51 PM |
| Amada Press Brake Controller problem | jamesbond007 | Bending, Forging,Extrusion... | 3 | 10-17-2009 03:49 PM |
| NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? | dsmdude | Bending, Forging,Extrusion... | 6 | 04-13-2007 04:01 PM |
