Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 09-14-2010, 08:40 PM
lourenco's Avatar
lourenco is on a distinguished road
Forged 6061-t versus 7075-t651
Hi Guys , i have been working in a racing billet brake calipers to my racing team.
Now the design is read to be machined ,but i have some questions...
Why the most billet calipers are maden from aluminium forged 6061-t ????
I cant make forging process in my shop, so i guess, if i could use the 7075-t651 instead of forged 6061???
Why do they use 6061 so much ? Is it a cheapest material?
What is the hardness brineel diferences between 7075-t651 and forged 6061-t?
Its easy to find 7075-t651 in my country (Brazil) ,the 6061 i cant find, only importing....
Thanks guys
Old 09-14-2010, 09:06 PM
Here are a couple of links with information about 7075 and 6061. I think 6061 is used because it is cheaper than 7075 and is widely available in North America. I also think anything that can be made out of 6061 can probably be made from 7075 without any problems other than 7075 not being as corrosion resistant as 6061.
http://www.unitedaluminum.com/aaa.php
http://en.wikipedia.org/wiki/7075_aluminium_alloy
Old 09-15-2010, 09:20 PM
lourenco's Avatar
i have a question...
what is the strongest aluminium ??? forged 6061-t or 7075-t651???
6061-t651=95 brinnel
7075-t651=150 brinnel
forged 6061=??????
How much brinnel hardness increase the forging process on 6061??
thanks
vm-1 versus newer vm10 converational versus g code powerstream HURCO 6 07-13-2010 02:35 AM
Milling 6061-T651 Cast Plate HimyKabibble Bridgeport and Hardinge Mills 19 01-18-2010 05:22 AM
Surfacing 6061 T651 aluminum hmc710 General Metal Working Machines 3 02-20-2009 02:34 PM
Ease of use.. GibbsCAM versus Mastercam versus BobCADCAM, etc.? squale General CAM Discussion 4 11-10-2008 04:41 PM
7075-T6 to 6061-t6 welding? AMCTony Welding, Brazing, Soldering, Sealing 7 02-04-2007 09:24 PM
