Results 1 to 11 of 11
Thread: how can make this part
    Nov 2007
    indonesia
    dear all,
    i run a metal stamping company, my machine are from 5 tons to 250 tons power press. i have a 50 ton hydraulic press machine.
    i have this project, i want to make about 50k product each months.
    the only thing i know that i can make this product is from extrusion, but i dont know anything about ekstrusion..
    attached is technical drawing from my part. is anyone can help me solve the problem?
    Attached Thumbnails Attached Thumbnails how can make this part-extrude.pdf
    Registered bwprice100's Avatar
    Jun 2009
    UK
    Hi
    Do a google search on DWI (deep wall ironing) used to make coke cola and beer cans
    Brian
    www.eBolt.co.uk
    http://stores.ebay.co.uk/ToolsAndBolts
    Nov 2007
    indonesia
    hi brian,
    thanks for the advice... still i dont understand how to make it..
    i have several times making a product wit a dies that i created.. im using a preheat also..
    well still dont have any luck... the part still crack... and crack every time..
    Jun 2009
    UK
    Hi
    it is not a straight forward process of just banging it out of a flat blank.
    See this link which gives some insight into the process
    http://www.toyo-seikan.co.jp/e/technique/can/making/
    The ounches and ironing rings are usually made from solid tungsten carbide.
    Also speed and precision are important. A can making machine can produce in excess of 500 hundreds of cans every minute. At this impact speed the metal can act more like a fluid than a solid.
    it is the total opposite of drawing where the body wall thickness increases in a controlled way the body wall thickness is made thinner by an ironing process.
    I hope this is of some further help
    brian
    www.eBolt.co.uk
    Nov 2007
    indonesia
    hmm...looks like possible technique..
    eniwei thanks briean..
    1 more question.
    can i make the prototype without using solid carbide for the ring? is it possible? and is it 50 tons hydraulic press will work?
    Jun 2009
    UK
    Quote Originally Posted by sonnybiker View Post
    1 more question.
    No Problem
    Choice of carbide is just to give longer tool life and dimensional stability.
    Not sure what tonnage press you would need I have never had to spec a press for this type of work so a bit outside my experience but I suppose it would depend on how many steps from intial cup to finished component you would like to do it in.
    The can making machines I have been involved with (we are talking mid 1980s here) did in in one hit from cup to finished can.
    Brian
    www.eBolt.co.uk
    Dec 2008
    argentina
    May 2008
    You will have to do it with at least 2 or 3 dies to get the result you want.
    Jeff
    Jul 2005
    That shape could be done by impact extrusion which is not as complicated as deep wall ironing. The deep wall ironing process is applicable to coated materials because it does not remove the coating.
    If you Google 'impact extrusion' you will get many links, here are some of them:
    http://www.extrudedprofilesworld.com...extrusion.html
    http://www.themetalcasting.com/impact-extrusion.html
    http://www.neumanusa.com/impactprocess.htm
    http://www.stalcop.com/impact-extrusion.php
    http://en.wikipedia.org/wiki/Impact_extrusion
    Your equipment is probably not suitable because impact extrusion has to be done with a fast impact at an elevated temperature not just a slow pressing process. An advantage of impact extrusion is that, depending on the tolerances, you can get the part finished in maybe two steps; one to form the cup shape and the second to trim it to length.
    Oct 2009
    croatia
    http://www.bonnydoonengineering.com/...20deepdraw.pdf this tool u see produce parts of ur dimensions,i made same for miself
    Nov 2007
    indonesia
    sorry..its been busy lately..
    eniwei, thanks for the effort guys
    1. How would you make this part?
      By kiramunch@sympa in forum Bending, Forging,Extrusion...
      Last Post: 03-23-2010, 01:44 PM
    2. Need Help!- I need someone to make me a part!
      By ryansuperbee in forum CNC Swiss Screw Machines
      Last Post: 09-30-2008, 10:36 AM
    3. RFQ Can anyone make this part?
      By Milt in forum Employment Opportunity
      Last Post: 09-18-2007, 08:34 AM
    4. Best way to make this part
      By skmetal7 in forum General Metalwork Discussion
      Last Post: 09-04-2007, 10:19 PM
    5. Can anyone make this part?
      By Milt in forum General Metalwork Discussion
      Last Post: 09-01-2007, 08:48 PM
