Results 1 to 4 of 4
Thread: How would you make this part?
    Dec 2007
    I need to make this part in quantity and economically out of a home shop enviornment. The material is .063 6061 aluminum. The slots and the holes are water jet cut and right now I am rolling the cuff portion and welding to tubing stubs. I would like to go to a 1 piece design to eliminate the welding as like the one in the picture. I do not have the money or room for a large stamping machine and dont mind if the solution is a slow one-at-a time pace with basic tools/machinery. Can anyone provide any suggestions? Thank you
    Attached Thumbnails Attached Thumbnails How would you make this part?-1_piece_armcuff.jpg
    Oct 2005
    How much are you allowing your
    Oct 2005
    How much are you allowing yourself to make a die and tooling? You could make a die that is closed with a hydraulic ram and opened by springs. To automate the ram a bit you could use a motorized pump instead of hand pump. A big question is, how many do you need to make? You lose so much time to rolling and welding/cutting, that you might job out the stamping part and be ahead.
    Dec 2007
    This item would be a constantly produced piece. We would probably make at least 100 at a time and just make more as the inventory got down. We dont mind starting out with a hydraulic jack type of affair and eventually motorizing. We have jigs for welding right now but it's not how we want to do it long term. A tool and die shop is a good suggestion.
  1. Need Help!- I need someone to make me a part!
    By ryansuperbee in forum CNC Swiss Screw Machines
    Last Post: 09-30-2008, 10:36 AM
  2. Looking for smb to make an aluminum part for me
    By DennyNY in forum Want To Buy...Need help!
    Last Post: 09-17-2008, 11:25 PM
  3. RFQ Can anyone make this part?
    By Milt in forum Employment Opportunity
    Last Post: 09-18-2007, 08:34 AM
  4. Best way to make this part
    By skmetal7 in forum General Metalwork Discussion
    Last Post: 09-04-2007, 10:19 PM
  5. Can anyone make this part?
    By Milt in forum General Metalwork Discussion
    Last Post: 09-01-2007, 08:48 PM
