Hello,
I´m have been operating and programming salvagnini p2 for 3 months. Now I would like to learn about ABS programming. I hope that someone could send me some program example to get started width ABS programming. I write my programs manually, not with Edit p4.
Andy
Hello,
I have not learned a basic course of ABS programming therefore its quite hard to get started. I found some examples from manual but they are bit hard to understand.
I am not sure if the ABS is enabled or not. Is there a easy way to see if ABS is activated or not?
I dont know how to check it phisically but you can insert one ABS command for your regular program and see what the machine say.
For example
ABS: Z1 15 Y1 -15
Okey thanx, I will try it out on monday
So what is your result?
Hi Guys, is anybody use StreaemBend S/W of Salvagnini, I have using it for 8 months now, I found it too hard to make ABS programming on. We had a basic training from the Salvagini guy, but due to it was new software, even he could not make ABS program on StreamBend S/W (strange), is any body has made ABS program on it?
