- Need Help!- Need to create bending system with Darley (Delem 65W) + KUKA (KRC2)
Hello!
Looking for experienced CNC programmer who is able to connect press brake Darley (Delem 65W control) with robot KUKA (KRC2 generation).
It should work as one (robot instead of real operator).
Robot pushes sheets in the press brake, press brake bends, robot takes the sheet out.
Robot and press brake should have common source to choose the bending program and common safety system.
- You may not post replies
- You may not edit your posts
Forum Rules
