Results 1 to 9 of 9
Thread: G0602 spindle nuts
    Oct 2007
    G0602 spindle nuts
    I know this is a dumb question, but I have to ask. Is there any magic to removing the spanner nuts on the back of the spindle? I want to replace the gear in front of the pulleys with an optical disc. I've put so much torque on the nuts the slots are starting to distort, and they still won't budge. I'm basically just holding the inside nut and trying to turn the outside nut CCW. Nothing. Are they reverse threads??
    Thanks,
    Jeff
    Oct 2007
    Update:
    They're right handed threads. Just needed more force. I had to make some longer spanner wrenches, BFS 9000's...
    Jeff
    Registered Crevice Reamer's Avatar
    Mar 2008
    Hi Jeff. Glad you got them loose. Just remember, the first one sets the preload on the spindle bearings, and the last one locks it.
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Oct 2007
    Thanks, CR. I was just about to ask that exact question
    Mar 2008
    YW!
    Adjusting G0602 Spindle bearing preload:
    1. Loosen adjusting nuts. (regular counterclockwise)
    2. Tap head stock until it has end slop.
    3. Tighten by hand until nut stops moving.
    4 Tighten with wrench another 1/4 turn.
    5 Hold that nut and lock the other against it.
    6. Run at high speed. If it gets hot, loosen slightly. If it stays cool is ok.
    CR
    Oct 2007
    Thanks for the tip. One of the bearings used to get pretty hot, but it stays cool now.
    BTW, if anyone plans to use the cnc4pc index pulse card with the g540, they are not compatible. The g540 wants 12V and the index pulse card outputs 5V. It took me a little while to figure out I needed to break out that wire from the g540 side of the parallel cable and connect it directly to the card.
    Jeff
    Oct 2008
    Pretty easy fix. I entered the information a couple weeks ago. Just neep to add a NPN transistor and resistor available from Radio Shack (used to be anyways).
    Oct 2007
    I ended up flipping the output to active low, and used a pull down resistor between the g540 and pulse card. I was dropping pulses the other way, not that many but it was enough to give me something like a 1% error in RPM. I was just guessing at the cause, but the error went away after I rewired it. I guess a transistor makes a better sink, but so far what I have works...
    Jeff
    Oct 2008
    I tried a pretty stiff pull down resistor but it wasn't working properly for me. I'm dead on with the NPN sinking it to ground. Glad you got yours going.
    1. leadscrew nuts and half nuts
      By jayhawkman in forum EBAY ADS
      Last Post: 11-07-2009, 02:00 AM
    2. G0602 tool holder Qs
      By Matt McColley in forum Mini Lathe
      Last Post: 04-22-2009, 10:07 AM
    3. G0602 Lathe conversion
      By SmoggyTurnip in forum Benchtop Machines
      Last Post: 03-05-2009, 09:54 PM
    4. G0602 Flex
      By rwskinner in forum General Metal Working Machines
      Last Post: 01-22-2009, 07:58 AM
    5. Need Help!- New G0602 10x22 cuts a taper
      By rwskinner in forum Mini Lathe
      Last Post: 10-31-2008, 06:34 PM
