Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: Sherline 2000, need Mach 3 XML....
    Feb 2010
    Hey There,
    I acquired a lightly used Sherline 2000 that was running the software that came with it. It runs under Linux operating system and I just don't care for it. I obtained a copy of Mach 3, and it looks amazing. Problem is, I don't have the XML for this Sherline machine. Can anybody help?
    Is there anything else I need to get it running?
    What about upgrading it? A controllable spindle on and off would be great.
    Thanks very much,
    Jim
    Tinkerer
    Nov 2009
    You would need a way of counting the revs and reporting them to mach. I used a Homanns design board to do the interface. Then you can do threading too. Mine works well though I not very patient with the sherline. Do you have Mach turn? Should be just matter of inputting the info. I would think the info in your linux regarding setup ports and pins and step and direction would all be directly transferable but I know nothing about linux.
    Feb 2010
    Sherline XML
    Hey There,
    I am looking for Sherline 2000 CNC MILL XMLs. Sorry I should have made that clearer. Thanks for your reply.
    Always,
    Jim
    Registered vlmarshall's Avatar
    Mar 2006
    Is there a separate XML file for the 2000? It has the same travels as a standard 5400 Sherline...
    I've just looked through my old Mach folder, and I don't see any separate file.
    If I had one, I dumped it with Windows on my mill computer, when I formatted it and switched to Ubuntu Linux and EMC a year ago.
    http://www.youtube.com/user/vlmarshall
    Feb 2010
    Talking Sherline 2000---5400 XML
    Hey There,
    Its the same basic unit, just more adjustable around the column.
    Maybe someone has this XML file????
    Thanks,
    Jim
    Tinkerer
    Nov 2009
    Jim I have a Sherline Mill XML that i run with a hobby cnc controller. Not sure of where I got it but it works with my machine. It wouldnt let me attach it or I would have. Tell me how to forward it to you here or otherwise and I will get it to you. John
    Feb 2010
    Hey Fastest1,
    If you can e-mail it---w.james.anderson@gmail.com
    Thanks very much for your assistance,
    Jim
    Tinkerer
    Nov 2009
    It kicked your address back as no email address found. Is this highlighted address correct?
    Feb 2010
    Sorry for the confusion...
    Tinkerer
    Nov 2009
    Sent
    Feb 2010
    Ok--I have a question now,
    I open the software and the Emergency stop is activated and I can reset it.
    I have everything plugged in, and the motors are ready and powered up.
    Any suggestions.
    Thanks,
    Jim
    Tinkerer
    Nov 2009
    Can you move the steppers? Do you know how? If you dont know how. First make sure your spindle is not in the way of hitting something. Turn off the power and position them manually and turn the power on if you dont know any other way. Now on the Mach MDI screen press "ref all home" all dro's will zero at this time. Now in the dialog box just to the right of the word"input" type in "G1 X1 F2" but dont use the quotation marks, press enter. At this time the machine should move in the positive direction 1" at feedrate of 2" per minute. The xml I gave you now that I think of it has been altered for my mill which has ballscrews and all kind of odd things. The distance yours travel will be incorrect but that is something to deal with as you move on with control. If you are running Sherlines leadscrews they are 1/4-20. They require 20 turns to travel 1 inch. Your stepper is probably set to 200 steps per revolution, so 4000 steps are required to travel 1 inch. My ballscrews are 3/8-5, they only needed 1000 steps for me. This is all adjustable you just have to figure out what you have. That MDI command I gave you will make your mill travel 1/4 as far until you change the steps per inch/or rev. It wouldnt hurt to measure how far it travels when the above commands are given. Hope this is what you meant when you asked for suggestions. John
    BTW Always be prepared with the emergency stop or esc key if you must but be prepared to stop it. Good Luck
  • Page 1 of 2 12 LastLast
    1. Replies: 14
      Last Post: 01-15-2010, 08:06 AM
    2. Replies: 8
      Last Post: 09-03-2007, 09:39 AM
    3. Taig MicroMill 2000 and Mach 2, Steps/Unit??
      By JV11 in forum Mach Software (ArtSoft software)
      Last Post: 09-25-2006, 10:32 PM
    4. New servomotors for my Sherline 2000-CNC - pics
      By Neil_J in forum Benchtop Machines
      Last Post: 06-28-2006, 09:42 PM
    5. Mach 2 & Win 2000
      By qsacracer in forum Mach Software (ArtSoft software)
      Last Post: 12-10-2004, 02:00 PM
