Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: X3 Acceptable Rapids speed
    Oct 2009
    Here's a question for all you speed demons. What do you deem as a reasonable rapids speed? I'm not trying to break any records, but it seems with my setup, anything over about 50 ipm can result in some random stepper stalling and lost steps. I know some of you claim 70 ipm is painfully slow, but setting up to 35 ipm and not worrying about screwing up a part makes sense to me. My gibs are snug and there doesn't seem to be any binding in the axis. I am nearly maxing out the voltage and currents for the steppers. So...what is an acceptable rapids speed?
    Feb 2006
    Quote Originally Posted by ronncat View Post
    Sounds to me like you significantly under-sized your motors. Either that, or your acceleration is way too high. If you get lost steps at only 50 IPM, you'll almost certainly be very marginal on torque at cutting speeds. And if you get stalling and lost steps at only 50 IPM on a single axis, you're also likely to see problems at lower speeds on multi-axis moves. Normally, you'd find the speed/accel limit, then back off as much as 50% for normal operation, to account for the dynamic factors of multi-axis moves, reversals, etc..
    Regards,
    Ray L.
    Registered Teyber12's Avatar
    Jul 2008
    Hey bud
    on my x3 i am running 80ipm on the y, 100 ipm on the x, and 60 ipm on the z. i can run much higher on the y but don't find a point, as before i know it SLAM i bang into the other end of the ballscrew only 6.5 inches away. On the x i have double nuts so it can't run nearly as fast, as there is a lot more friction between the ballnuts and ballscrew. I can run it up to 140ipm but sometimes i don't trust it and don't see a point in going any faster. On the z im also double ballnuted. I can take it up to 80ipm but sometimes it stalls. You can fiddle with the z axis gib adjustment. Personally, id rather have tight ballscrews with minimal backlash and "slow" rapids that make my parts take seconds longer
    I hear people getting wild speeds here and kind of blows my mind.
    if i were you i would keep it at 35 ipm. seems like rapids in our situation is sort of like 95% of the car scene... you get envy and want to make your car as fast as possible, but unless you are one of the few who actually races it really doesn't make a difference..
    Gold Member hoss2006's Avatar
    Apr 2006
    What's acceptable is what satisfies you and it sounds like you have the right mindset.
    Teyber has it right too, wicked fast rapids are for bragging not practical use.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Apr 2006
    If you've seen someone on here with the same setup as you but claiming better rapids,
    send them a PM and ask for their setup parameters. You may, however, find their practical speeds
    are actually much lower.
    Hoss
    Oct 2005
    It depends. As Hoss says, it's an attitude thing most time. If sitting in a boat waiting for a fish to bite doesn't frustrated you, slow rapids won't be hard to take. If you find yourself casting and trolling and pissed when the fish aren't biting, you will need faster rapids. I'm finishing up a JGRO with 1/2-10 lead screws and in testing, the Z flies at 240+ ipm, with the X and Y move at 180ipm reliably. I expected 60 or less. Lot to be said for the G540 and a 48v power supply. I'm expecting far less from the Probotix set up I bought off a Zoner as it has weaker motors, 24v power supply, and anemic drives. If I get 40ipm on the X2, I'll be content.
    Registered neilw20's Avatar
    Jun 2007
    Talking 120 IPM.
    My Syil SX3 (factory CNCed out of the box) will run at 120 IPM (3000mm/min) but I limit it to 60 IPM (1500) so that even if the pulse stream is interrupted by DMA stealing time from the Mach3 low level driver I do not lose steps due to instantaneous decelerations.
    I am machining expensive material and for the sake of 7 seconds per machine cycle I will live with the slow rapids.
    Who wants to cut air at high speed any way.
    60 IPM is ultra reliable, using a 48v supply and Mach3 running at 35KHz with a 2G Celeron and 256M ram running 6 hours per day, 4 axis.
    At only 25KHz (for some un discovered reason) I get more clunking.
    Clunking is instantaneous stopping of the pulse stream for short periods of time. I surmise that at 35KHz the clunks are of a shorter duration, so not as noticeable. Still clunks (more quietly - almost un-noticed compared to 25KHz), but it works OK.
    I use 45IPM (1100mm/min) rapids for the Z axis.
    My microstepping is set to 10 which is more than enough precision for my needs. 1000 pulses/per rmm
    The bigger the divide ratio (more steps) will limit your rapid speed, but improve accuracy. If you can decrease accuracy you can have faster rapids.
    I am using Mach3 version 2.26 as I have had unexpected 'hangs' in later versions. None of the new features seem to be an advantage to me. Reliability is EVERYTHING when machine material that has already had $50 worth of work already added before I machine it with a 2 minute cycle time.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Registered Torsten's Avatar
    Nov 2004
    U.S.A.
    Most of all it has to be reliable, then there is a added advantage to slow rapids as it gives you a chance to stop when you see it take of in the wrong direction before you scrap a part.
    As a general speed I feel been able to travers your longest Axes in about 30 seconds is adequate for my machining needs, so it will depend on the size of your machine.
    Industial strength Rapids at over 1000 IPM will save some time in mass production.
    For most small quantity stuff it makes little difference, setup times will dominate most of the time spend.
    Aug 2006
    I wish I knew how to slow mine down! I'm getting over 200ipm rapids and don't like it. It rocks my whole x3 and table like a toy. I keep hand tweaking my gcode to replace the G00 rapids with a G01 feed for a more reasonable speed of 90ipm.
    I'm using servos but to give you an idea; the nema34 torquemaster servo that I'm using on the Z axis has a peak torque rating of 896oz/in and a continuous stall torque of 100oz/in @ 4600rpm. I'm using smaller nema23 servos for the X and Y axis which are rated at 50oz/in cont, 355 peak and 35oz/in, 260oz/in peak (respectively). Not sure if that helps you much.
    I purposely upgraded to more powerful motors than my machine can handle and I really like it that way, but I really wish that I could slow the rapids down somehow. I don't want to limit the current or modify the servo tuning parameters to achieve this though - just want to slow the rapids down. Does anyone by chance happen to know if this can be done in Mach?
    Jul 2008
    Quote Originally Posted by yantra3d View Post
    you can change it under config- motor tuning at the bottum (at least with steppers)
    cheers
    Jun 2007
    Thumbs up Reduce overall speed. easy..
    Even without config, on main Mach3 screen set feed override to say 25% and the rapids will slow down too. The g01 will only go at 1/4 speed too.
    Hit the tab key, and set the feed window to say 10% to make the arrow keys less scary.
    Shift and the arrows will go at full speed.
    In Config >motor tuning you can set maximum speed each axis.
    You must hit the 'save' button for each axis as you change it.
    Aug 2006
    Thanks guys! I'm saving this info for when I finally get plugged into mach (soon I hope).
  • Page 1 of 2 12 LastLast
    1. What is an acceptable endmill tir?
      By papa_rr in forum Toolgrinding & Toolgrinding Machines
      Last Post: 09-12-2010, 05:39 PM
    2. Tormach Stepper Speed During Rapids Question
      By BobWarfield in forum Tormach Personal CNC Mill
      Last Post: 10-06-2008, 11:05 PM
    3. What speed rapids can I do with the xylotex?
      By lagfish in forum Xylotex
      Last Post: 03-27-2008, 01:47 PM
    4. Is this an acceptable axis layout?
      By LN-JET in forum Vertical Mill, Lathe Project Log
      Last Post: 01-20-2008, 08:01 AM
    5. How much spindle runout is acceptable?
      By sbalder in forum General Metalwork Discussion
      Last Post: 12-13-2006, 10:11 PM
