#37
| Ahhh, it's the fractions. The answer is so obvious now that you explained it. Initially, I thought it was such an odd number. Maybe all mills have odd numbers. Intuitively, just expected something round for inch screws...like .2" per crank turn. Thanks. |
#39
#41
| Thought I'd post a few pics since uploads seem to be working again. Sure is a perty thang. Hoss Got the specs for the Precision Mathews PM20MV and PM25MV below.
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
#44
| Yeah, there are a couple of items in the specs that are a bit odd. Like the table sizes being the same and yet the travels are different by over 2 inches? I got the PM-25 so when it gets here I'll measure the travels. I will be a bit angry if the motor specs are wrong, I took it that the extra power was a part of the price difference on it. |
#46
| so the differences between the 20 and 25 are simply spindle motor horsepower? Or if the travels they list are correct, you get more X on the 20, but more Z on the 25. If Grizzly is going to be a long wait, I might just get one from MTW (they are in Canada which helps).
__________________ FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info. |
#47
| That's right, all you guys should cancel your grizzly orders and get the PM mills so you can have it like tommorow., But wait on the electonics till after I get mine so they're not back ordered as well. Brian PS-I feel like I'm moving up the list quickly.........LOL |
#48
| the 25v / lv is more power and r8. those are the only differences from weiss, but each oem seems to be able to alter the specs to their own needs. for example MTW took the bf20 models and requested r8 in them which isnt standard form the opti factory. as for the travels being different, this is likely just the way the limit stops are set up. it could also be a revision in the saddle casting that allows more movement on the grizzly. theres been a number of tweaks to the mills over the years by the look of things. the 2 may also not be from the same factory either. |
| Currently Active Users Viewing This Thread: 3 (1 members and 2 guests) | |
| frostheave |
| New grizzly G0704 | madtownrob | Benchtop Machines | 565 | 05-07-2012 04:10 PM |
| Hoss's ZX45 | hoss2006 | Benchtop Machines | 197 | 02-17-2011 06:30 PM |
