Results 1 to 11 of 11
Thread: 4th axis do-it-yourself
    Apr 2009
    Ok I have a benchtop (x4 like) CNC that works great. It came with controller and 4th axis board. All that is missing is 4th axis itself. I am thinking about 4" item. I know I could just buy one off the shelf but I would like to convert one myself ! I need a rigid donor rotary table and a stepper motor to get started. Any suggestions?
    Jun 2006
    Stavanger, Norway
    Pick an RT that has good backlash adjustment, both on the gear engagement and the worm shaft. You can live with a bit of backlash on a manual RT, it can be a nightmare on a CNC RT.
    Phil
    Quote Originally Posted by zaebis View Post
    Feb 2004
    Reno, NV
    Here's one I made from a 4" Phase II table. The table was purchased from LMS. The table has a backlash adjustment and you can make it as tight as you like.
    Attached Thumbnails Attached Thumbnails 4th axis do-it-yourself-fourth_axis5.jpg   4th axis do-it-yourself-fourth_axis4.jpg   4th axis do-it-yourself-rotarytable1.jpg
    ~Don
    Jul 2008
    UK
    Quote Originally Posted by degreaser View Post
    Thats very similar to a conversion I am doing at the moment. Did you do anythign to the shaft - e.g. fit thrust washers or other bearings, or just bunged the motor on?
    If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
    Feb 2004
    Reno, NV
    No thrust washers, I just used the stock movement. That's a good idea though.
    It currently has a homebrew lovejoy coupler to connect the shafts but I'll eventually replace that with a helical coupler.
    ~Don
    Registered kanton's Avatar
    Jun 2003
    degreaser,
    How large is the hole through the center of your fourth axis?
    Thanks.
    Feb 2004
    Reno, NV
    Kanton - do you mean through the rotary table/chuck bore or through the NEMA23 mount?
    Through the bore, it's around .597". I'd have to pull the mount off to get the other measurement but the ID of the mount is the OD of the backlash adjustment bushing on the table. It's around 1.25".
    ~Don
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Question
    Degreaser "Don",
    Is the stepper mount for your fourth axis one piece?
    It looks very good.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2004
    Reno, NV
    Thanks! Affirmative. It was turned from some 2.25" 6061 square stock.
    ~Don
    Jun 2003
    degreaser,
    I wanted to know the approximate maximum diameter of a long item that you could fit through your fourth axis?
    Thanks.
    Feb 2004
    Reno, NV
    That would be .597". That's limited by the design of the 4" Phase II table.
    ~Don
    1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
      By begacon in forum Knee Vertical Mills
      Last Post: 07-30-2009, 07:31 AM
    2. New Machine Build- post for 2 axis ez trak versus 3 axis ez vision
      By tooolman in forum G-Code Programing
      Last Post: 11-28-2008, 04:33 PM
    3. Compare Catia and MCX2 for multi axis lathe/4 axis mill
      By bob1112 in forum General CAM Discussion
      Last Post: 10-10-2008, 08:15 PM
    4. How can I coupling a stepper motor axis directly to other axis?
      By meknik2001 in forum Stepper Motors and Drives
      Last Post: 05-08-2008, 02:54 PM
    5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
      By the__extreme in forum CNC Wood Router Project Log
      Last Post: 02-26-2007, 03:58 PM
