Might be the stand underneath it that amplifies the noise. I reduced a good portion of the noise now that my X2 sits on a big foam archery target (with a plank in between for stability).
I had an x1 and swapped it for an x2. The x2 seems to be much louder than the x1. It has a much higher pitched whiney sound. The x1, was relatively quiet. Is this normal?
It's just that I used to be able to get close to the x1 without it hurting my ears, however with the x2 it hurts my ear if I'm really close to the machine. I get close to the machine sometimes to see different angles.
Anyone wear hearing protection when using these small mills?
Convert to a belt drive and you'll hear a big difference.
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
