A friend of mine bought a 1100w spindelmotor with a controlboard that should fit the SX3 perfectly. it has a controllpanel for manual use and LCD display that can be used instead of the original one. He hasnt had time to fit it to his mill yet. It can easily be controlled in mach3
Its made by a company called sangmutan
http://www.sangmutan.com/eng/pc.asp?id=412
the price is about 450dollars for the kit.
Does anybody have experience with this kit?
Do you have more info on the novakon kit?
Nope. And I probably won't have the kit until next week sometime. Then we're all going to have fun figuring out how to connect it.
I hope you have a wiring diagram. The actual motor and hall sensor wires are straightforward. And the Estop, spindle guard etc are also no problem. It's going to be the OTHER connections that will need worked out.
The Novakon board has 3 wiring plugs to a daughter board with a total of 13 wires. The SX3 only has 10.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
There is a wealth of information in these 3 threads:
NM-135 (KX3) spindle trouble
SX3 spindle driver replacement
SuperX3
CR.
