I mentioned in post 113 that I thought you would have no trouble.
I was apparently wrong. Your video don't play. Still.
Something else to consider is the impact to the system of using a higher acceleration. Mine are withing the 10 to 20 range IIRC.
Mach does a good job of letting a machine run smooth. I think a slower acc. helps with everything involved and doesn't cost a lot of time.
