I think this machine is good. The machine comes with ball bearing screws on all three axes. Also are the two X axis guide pins are fully supported for extra steadiness.
Hi i'm new here and a totally newbie when it comes to run CNC machines.
I need some advice regarding "Tonsen" CNC6040, CNCDIY Machines say they sell Tonsen machines but im not 100% sure if this is Tonsen. Tonsen seams to be a nice machine for that kind of money according to you guys in this thread.
I have been in contact with CNCDIY Machines about CNC6040 But we are actually looking for a plug-in-ready-to-run adhesive dispensing robot (XYZ) like http://img.alibaba.com/photo/2063900...nser_robot.jpg to applying adhesive precisely on plastic parts (ABS).
Would it be possible to use a CNC-router (without a spindle) as a XYZ-"robot" to apply the adhesive?
We already have the adhesive dispenser equipment but need a XYZ-"robot" to move the syringe around the 3D-space.
The seller promised me to deliver the machine with a controller with a output relay that can be controlled from the Mach3 program. The is essentially to control the on/off of the adhesive flow.
As i'm a mechanical desinger working in Solidworks, i could maybe have some fun with it as engraver and milling machine too.
Is it a good machine?
Thankful for any comments, Peter
No replies here though..... But i bought it anyway. 1250usd plus 150usd for shipment from HK to Thailand with TNT-economy.
Have you got the machine? Do you like it?
