Honest, simple solution......I'd get a 30gb ide HD and use your old machine - this should be the least $$$, or next, swop out the new pc motherboard for another with a parallel port - they are still available.......just!
Both options will allow you to hook up the scanner and printer to a parallel port switch box although you won't be able to use all at the same time. I wouldn't be tempted to add a pci card to the new pc - these seem to be very hit or miss when used for machine controls!
Using a USB smoothstepper or similar is an option but prob. more expense and still doesn't help with the printer / scanner hook up!
LinkBack URL
About LinkBacks
