Results 1 to 4 of 4
Thread: The matched G540/387ozin stepper motors are...
    Oct 2005
    My math was wrong. The 387inoz has over 1NM of torque right up to 750RPM
    Sep 2003
    OK
    I think something has been lost in translation. The best bang for the buck motor available today is the 381 oz motor. http://www.kelinginc.net/KL23H2100-35-4B.pdf . The inductance is much lower then the 387 and will allow more torque at speed. At this time it has the highest torque/lowest inductance and the best fit for the G540.
    The difference in cost is minor. My suggestion for X2 would be the 381 oz on all axis mated with a G540. Granted its a bit of an overkill on the X and Y but for a few dollars more who cares!
    Jeff
    Registered Jeff-Birt's Avatar
    Feb 2007
    The biggest motor that your drive will run is seldom the best motor for an application. That is kind of like thinking the biggest engine that will physically fit in your car's engine compartment is the best. You stepper should be matched to your machines requirements and then the drive/power supply should be matched to the motors.
    Motors that are wound (or just rated) to match the maximum specs of a popular drive should be a red herring.
    Jeff Birt
    Sep 2003
    OK
    " Motors that are wound (or just rated) to match the maximum specs of a popular drive should be a red herring."
    In this particular case I would still keep the "Red Hearing"
    Will using the 381 oz decrease his performance in torque or speed?
    Will using the G540 not save him money compared to using standard Geckos most use for the reliability factor?
    I have seen it happen many times here on this forum where one gets a smaller mill to learn on then upgrade to a larger mill later. With the package above he will have 90% of the equipment to make the upgrade.
    Change can be difficult for people to accept. But there are a few things that drive it. Cost, quality, ease of use are just a few. Innovation based on a changing world should be dissuaded?
    " biggest engine that will physically fit in your car's engine compartment is the best. "
    I can tell you never owned a "GMC Sonoma". I was almost killed 3 times because it did not have enough power to enter traffic on the highway! So "yes", if the cost is reasonable give me the power!
    Views expressed above are not to be considered those of this fine community but solely the personal opinion of the writer!
    Jeff
  1. Motors to use with G540.
    By samsagaz in forum Gecko Drives
    Last Post: 11-13-2009, 05:09 AM
  2. Keiling motors and G540 connections Help
    By bevins in forum Automation Technology Products
    Last Post: 09-04-2009, 04:59 PM
  3. Config for 2 motors on x-axis (w/ Gecko g540)
    By rogerer in forum LinuxCNC (formerly EMC2)
    Last Post: 05-16-2009, 10:30 PM
  4. Need Help!- Need Motors for G540
    By bd007 in forum DIY CNC Router Table Machines
    Last Post: 03-23-2009, 08:00 PM
  5. Need Help!- Looking Stepper Motors for G540.
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 03-22-2009, 05:46 PM
