Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: stepper couplers
    May 2005
    stepper couplers
    It's time I started looking for some couplers. Anyone have a good source?
    Do I need to pay attention to coupler torque specs, or are these steppers (<400 in-oz) too small to worry about this?
    tom
    Sep 2003
    OK
    Yes worry.
    I had some problems with backlash when I tried to use small cheap helicals on some 381 oz.
    I have used some from US Digital, and CNC Fusion sells some decent ones. Make sure they are about 1" in diameter or so, the 1/2" ones are not gonna cut it unless they are steel.
    Jeff Davis
    Registered Crevice Reamer's Avatar
    Mar 2008
    You will want the clamping type. I have not tried these, but it's a good company and they look decent, if you can deal with the 1/2/1/4 shaft sizes:
    http://cncrouterparts.com/product_in...products_id=51
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    I have not tried them myself, but I've been eyeing the ones from Stock Drive Products. They seem to have the largest selection of sizes.
    Fred
    Mar 2008
    Quote Originally Posted by TXFred View Post
    Fred
    Do you have a link?
    CR.
    Aug 2009
    Austin, TX
    I can't link directly to them, so try this. Go here:
    https://sdp-si.com/eStore/
    On the left side, click on Couplings, then Helical, then Commercial Series. You will get a list, and you can refine by dimensions, material and torque rating.
    Fred
    Aug 2009
    Austin, TX
    Quote Originally Posted by tooManyHobbies View Post
    I noticed that nobody's addressed this question yet, so here's my non-expert opinion, formed by reading books and eating the brains of really smart people.
    In my case, my motors are 381 in-oz. That translates to 23.8 in-lb.
    In the case of torque on a coupling, the motor torque is only one of two factors. The other is the resistance of the table. The only time I should see the full torque is if my table stalls, either during a cut or by running to its movement limit. The rest of the time, I am expecting the torque to be less than the maximum.
    Viewed another way, if it takes 100% of the motor's torque to move the table, then the slightest increase in resistance will cause the motor to miss a step, ruining your workpiece. You should be set up so that you're never demanding the maximum from the motor (and by extension, the coupler).
    Many people seem to be using aluminum couplers. But from what I see on the SDP site, these couplers are rated at half the torque of my motors. So it looks like you can get away with a weaker coupler. What happens when you make a heavy cut, crash the mill, or run to the table limit is another matter. At that point the coupler will be overloaded.
    Will it shatter? Doubtful. Will it bend? Maybe. Most likely, though, the torque rating is based on the amount of torque a coupler can transmit before it begins to twist and introduce backlash into the system.
    This means that if you feed too fast, tighten your gibs too much, or cut too deep, you might get more backlash. So then you feed slower, loosen the gibs a touch, and make shallower cuts. It won't be the end of the world.
    I'm still waffling on the issue myself. I can save $20-40 by getting the aluminum couplers and possibly compromise my build. Or I can get the more expensive stainless couplers and know that they'll take whatever my motors can give without complaint.
    Anyway, that's my two cents on the matter.
    Mar 2003
    Shelby Twp, MI....USA
    Try these, rated at 28in-lbs of torque.
    http://www.mcmaster.com/#9861t5/=4z5r2z
    Mar 2003
    I believe these are the couplers that SDP sells. I have these and the specs match up.
    http://heli-cal.com/db/Products/Search.php?SearchID=3&DatabaseID=3&ProductSeries[]=ACR&Search.x=49&Search.y=7
    Nov 2005
    Alabama - USA
    The first note on the Helical catalog page for the 17 lb-in couplers I got at a great deal pretty much told me I couldn't use them.
    Dynamic torque ratings are momentary values. For non-reversing applications, divide by 2. Divide by 4 for reversing applications
    There is also another rating on these. For mine:
    Torsional Rate - 0.28 degree/lbin
    Sep 2003
    OK
    Aluminum couplers are fine, you just cant use the cheap little half inch diameter ones. Mine on my 381 oz motors are aluminum now but they are beefier then the original ones I tried to use that did give me some backlash problems.
    Jeff
    Mar 2003
    Quote Originally Posted by Mike Nash View Post
    Mike, do you have the same ACR087-8-8 that I got for $5 each?
    I'm using them with 250 oz-in motors and they're working great for a few months now.
  • Page 1 of 2 12 LastLast
    1. Which Couplers?
      By caleb105 in forum Benchtop Machines
      Last Post: 02-22-2009, 09:49 PM
    2. Trying to find ballscrew to stepper couplers. Metric to Imperial?
      By thkoutsidthebox in forum Linear and Rotary Motion
      Last Post: 08-11-2008, 12:47 PM
    3. stepper couplers
      By corrie in forum Stepper Motors and Drives
      Last Post: 06-03-2008, 12:45 AM
    4. shaft couplers
      By dgalaxy in forum Benchtop Machines
      Last Post: 02-01-2006, 12:18 PM
    5. shaft couplers do i need
      By craftech in forum DIY CNC Router Table Machines
      Last Post: 11-29-2004, 10:26 AM
