The wiring diagram is not clear on how the two are connected. any help out there?
Hi vz!
The screw on the far left is to adjust the voltage up and down. Once you have all motors locked up--adjust this to 50V.
The next three terminals are for Plus Voltage wires. You will have only one wire from one of these to terminal 11 on G540.
To the right of those three are the three Negative Voltage terminals. You will have only one wire from one of these to terminal 12 on G540.
The last three terminals on right are for line cord. If you see an appliance sitting out for trash--cut off the 3 prong cord, strip the wires, and mount it here.
First terminal on left is the ground, (long round prong, green wire) next to right is neutral (larger flat prong, white wire) and last on right is the hot wire. (smaller flat prong, black wire)
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
