Results 1 to 9 of 9
Thread: What are Z grooves?
    Feb 2009
    What are Z grooves?
    While waiting on my deluxe cnc fusion kit (haven't heard from Michael in about a week...) I want to polish my X3 ways/gibs.
    I came across a couple of posts mentioning cutting Z grooves into the gibs. I did an exhaustive google search and came up with nothing. And then couldn't find the thread I had originally stumbled upon.
    Can anyone shed some light?
    Moderator HuFlungDung's Avatar
    Mar 2003
    The Z groove is just a description of the shape of a lubrication channel in the gib. The web of the Z is angled diagonally across the face of the gib so that lubrication will spread across the entire face of the sliding surface. The shorter parts of the Z-shaped groove are really only necessary to connect with the holes where the lubrication enters. They may also add extra lubrication at each end of the gib where lubrication is lost and minute grit is most liable to enter.
    Feb 2009
    Thanks, I thought it might be something like that. I was hoping to find a picture on whether it was one large groove or many grooves, etc. Guess I'll do this if I ever come up with a one shot oiler system.
    Oct 2009
    canada
    Registered Teyber12's Avatar
    Jul 2008
    Quote Originally Posted by rezcar View Post
    don't worry about cncfusion you will not be unsatisfied with customer service...
    Lot of $ out of pocket for the kits and there is a LOT of machining time that goes into each kit so it takes a couple weeks for them to get the kits out.
    Feb 2009
    THANK YOU for that!
    I actually found the thread I lost before, the poster misspelled "grooves" twice, no wonder the search couldn't find it.
    Feb 2009
    Quote Originally Posted by Teyber12 View Post
    Got my UPS notification, it arrives Friday! Yay! I haven't even polished the ways/gibs yet, was so busy moving the mill electronics to the same case where my PSU/G540 are mounted. Then I got into making a relay box, etc, etc.
    Nov 2005
    Z Groove Pic's
    Enclosed are several Z Groove Pic's found on the various Threads
    authored by SJH (Steve).
    Attached Thumbnails Attached Thumbnails What are Z grooves?-gilmanslide001.jpg   What are Z grooves?-gilmanslide002a.jpg   What are Z grooves?-hbmprogress004.jpg
    Feb 2009
    Sweet.Guess I'd need another mill to cut the grooves though.
    1. grease grooves
      By wbrumfield in forum General Metalwork Discussion
      Last Post: 09-15-2009, 04:51 PM
    2. Need Help!- Oil Grooves
      By gmilosevic in forum Want To Buy...Need help!
      Last Post: 02-24-2008, 06:03 AM
    3. Whats the best way to get these grooves..
      By kprice1658 in forum Rhino 3D
      Last Post: 08-17-2007, 04:26 AM
    4. Grooves MCX
      By jorgehrr in forum Mastercam
      Last Post: 04-18-2007, 04:58 PM
    5. Machining grooves
      By itsme in forum General Metalwork Discussion
      Last Post: 10-03-2005, 02:07 PM
