Results 1 to 4 of 4
Thread: dropped ball screw bearings from Syil X3 conversion kit
    Nov 2009
    Hi, I'm a new teacher and inherited a grizzly/syil x3 conversion. Since I was trying to figure it out with no idea what I was doing, I managed to back the Y-axis screw out of it's nut and drop the bearings. Apparantly the former teacher had done the same to Z so I need two axes repaired. (Also note: the Y-axis seems to have been missing the stop-ring at the end of the screw. Haven't seen Z yet.)
    Would you reccomend buying replacement screws from Syil (or someone else), shipping off the screws for repacking (know any reputable repair shops?), or trying to repack myself. In the last case, does anyone know what bearings I need to buy? Is the replacment from syil the only way I get the stop-ring (anyone know what you actually call that?) so I don't do this again.
    Also, since I'll have it all apart, anything else I should consider? I'll install the limit switches but I think I read where the old syil optical limits lack accuracy. Buy their new ones? Another good alternative?
    I'd appreciate any general or specific info you don't mind sharing.
    thanks in advance,
    jb
    wam
    wam is offline
    Aug 2003
    Arizona
    I'm not totally familiar with your specific type of ball screw but....I am in the middle of an X2 conversion and I have re-loaded my balls a few times. It takes some practice but its not rocket science. If you are missing balls you can measure and get replacements. I would replace all the balls with ones from the same supplier. That way you can be sure that they are indeed the correct size. I have bought some replacements from VBX but ebay is a good source for odd sizes.
    Nov 2009
    thanks wam. i don't trust myself even using calipers to measure this very precisely. if i'm shy 1/64th, you know if pretty close is good enough for small ball screws?
    thanks,
    jb
    wam
    wam is offline
    Aug 2003
    Arizona
    Well if they are the generic inexpensive 5/8 rolled ball screws that most of us use on this conversion then my guess is that the balls are .125". I think I saw a thread that Hoss has loaded .1259 balls in his screws to reduce backlash (can I say that?)....
  1. Need Help!- Bmc ball screw support bearings
    By JWC in forum HURCO
    Last Post: 09-27-2008, 10:56 AM
  2. Problem- VMC 2216 Thrust Bearings and/or Ball Screw
    By Billet Sean in forum Fadal
    Last Post: 08-30-2008, 09:25 AM
  3. Attaching bearings to a ball screw
    By ranchak in forum Linear and Rotary Motion
    Last Post: 09-22-2007, 01:01 AM
  4. installing ball screw bearings
    By dgalaxy in forum Bridgeport and Hardinge Mills
    Last Post: 09-01-2006, 10:06 AM
  5. Ball screw without bearings?
    By Halfnutz in forum General Metalwork Discussion
    Last Post: 06-13-2005, 04:10 PM
