Again, I have to wonder if the author of that post actually took the time to *measure* the flex, and determine *where* it was coming from, before jumping to the conclusion that the column mount bracket MUST be a significant contributor. I've only once seen anyone actually take the time to do this (John Pitkin on the Yahoo mini-mill group), and he found the bracket to be a very minor contributor - not even worth messing with. Too many people come up with a "fix", and declare the problem solved, without first taking measurements to prove what/where the problem is, or even to prove that the "fix" really improved things. I've seen an awful lot of "fixes" that actually made things worse! Without measurement, it's all just speculation....
Regards,
Ray L.
LinkBack URL
About LinkBacks
