I'm looking for a good, reliable source for *reasonably* priced bearing mounts of this style for 20mm ballscrews: http://www.midwestmotionproducts.com...fk%20ver-1.pdf Most of the ones I've found are just stupid expensive. Anyone have any ideas? Regards, Ray L. |
Ray you are probably looking at BK/BF 15mm for a 20mm screw. linearmotionbearings...Google search.ebay store. A20mm set is $59.I didnot see a 15mm set but he has them.E-mail him to check stock Larry BTW they are scarry cheap
__________________ L GALILEO THE EPOXY SURFACE PLATE IS FLAT Last edited by lgalla; 10-30-2009 at 06:12 PM. Reason: add |
| Regards, Ray L. |
| Ray, the square part that resembles the FK/FF type on a BF/BF is just the bearing retainer plate - the bearings are mounted in a bore in the main body of the block. Keep an eye on the quality if you're going for the cheapies - mostly they're ok, but some aren't. Fortunately, most sellers of the cheap ones are pretty good about replacing faulty products. I stick with NSK's WBK series now, but they might not offer the best price/performance balance for your project. Best regards, Jason Last edited by Jason3; 10-30-2009 at 07:40 PM. Reason: Add pic of cross section... |
Hay Ray BK/BF are THK part numbers.I dought they are not knockoffs from linear...b.yer FK's are probably Chinese knockoffs too. I have origional THK's,BK/BF and the BF floating side has a bearing made in China. I don't understand,did you ask LMB for FK's or BK/BF,which they stock.If you want THK's they will be $200 to $300.The outher factor is are your screws machined for the blocks?If not...You thought the bearings were expencive sit down!!! Larry
__________________ L GALILEO THE EPOXY SURFACE PLATE IS FLAT |
| Somebody pointed me to another good source: www.misumiusa.com Looks like decent quality, and reasonable prices. Regards, Ray L. |
| Larry, You stated that if the balls screws were not machined for the block to sit ( I think you meant cost wise) I am considering buying a ballscrew that needs the ends machined, but am unsure of cost, or who to take it to. |
| Robert Spalesh (or maybe Palesh...) rspalesh@fairpoint.net (440) 813-0920 He does excellent work, he's fast, and a lot cheaper than anyone else I know. He did all the screws for my knee mill conversion for about $200. Regards, Ray L. |
#10
| Hi Ray I see a lot of concern being expressed about the cost of the angular contact bearing blocks. Since these were / are intended for use in precision machine construction a lot of the cost is not in the bearing but in the machining of the block. The block - or at least the better quality ones - will ensure that the shaft lines up parallel with the mounting face. This is worth it only if used with a floating block at the other end AND if the two blocks are mounted to ground flat faces known to be in the same plane as each other. With home brew machines this is probably not going to be the case due to the method of construction and the methods used. Thus a lot of these precision bearing mount properties are wasted as the bearing mounts have to be shimmed to bring the bearings - shaft and motion travelled into alignment. So why not make your own bearing blocks assuming you are going to have to make adjustments to the mounting on assembly rather than pay through the nose for precission that was intended to give rapid bearing changes on production machines. Suitable bearings can be found in the attached see page 53 and onwards. http://www.skf.com/files/151315.pdf The cheapo suppliers have this bearing series on sale for arround $10 genuine SKF ones will cost more. I have purchased a number of these in non branded form and found that there is enough preloading built in to give no measurable movement in the radial direction and still have reasonable free movement in the axial considering mine have all been 2 RS types. With the pre loading set by the manufacturer the double row angular contact bearing is easy to mount. Yes I know I don't like giving my money away - my excuse is that I have retired so am cash poor but time rich but I still don't have enough of the latter! Regards Pat |
#11
| I use Misumi quite a bit, they even custom modify some items for a reasonable price. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#12
FWIW, IH makes their own blocks that are integral to the motor mounts. They work great and sure seem like a more elegant solution than trying to integrate a third party component. Cheers, BW |
| help for mount bearing ballscrew | p_rabid | Linear and Rotary Motion | 0 | 05-16-2009 04:11 AM |
| Ballscrew bearing question | pstockley | Mechanical Calculations/Engineering Design | 3 | 05-16-2006 05:21 PM |
| Ballscrew sources | ozzie34231 | General Metal Working Machines | 0 | 02-22-2006 08:28 PM |
| 2- Micromill bearing blocks and mounts. | radicooldude | Employment Opportunity | 3 | 01-13-2006 10:51 PM |
| bearing mounts - ballscrew | cadman | Fadal | 1 | 05-25-2005 06:11 PM |
