Hi, I have a very basic question/confusion. From my point of view there are at least two basic types of CN control: 1. The controller/software sends stepper/servo signals according to some code and the hardware controller controls the steppers/servos accordingly (open loop). or 2. Like 1., but the controller/software reads the DRO data to measure the actual travel (closed loop). The second alternative allows exact (up to the accuracy of the DRO) absolute positioning regardless of backlash or any other mechanical issues, the first alternative does not. Now my question: How are hobby conversions typically done: closed, open or something entirely different? It seems to me that -if the software supports it- a closed loop system has tangible benefits and is not considerably more complicated than an off-the-shelf DRO. Are people doing this? -Jan. |
| I think the vast majority of benchtop CNCs run w/ Mach3 and EMC use open loop steppers. Whenever the "stepper vs. servo" topic comes up, most people vouch for steppers, citing simplicity (if properly designed) and lower cost. Personally, I use servos, but the encoders are integral to the motor. If you already have the scales for a DRO, it makes good sense to use them. I don't know much about getting the signals back to Mach3, I'm sure someone else will chime in. The glass scales on my lathe dro output single ended quadrature, which any number of servo or data acquisition systems can use. I agree that it doesn't add much complexity, whether it's a true servo motor or a stepper with position compensation. There are motion controllers that will treat a stepper as a BLDC motor and run it as a servo (Copley Controls for one), but this approach limits motor performance compared to simple micro stepping. |
Mach3 is "open loop", regardless of whether you use servos or steppers. Mach3 tells the machine where to do, and it is entirely up to the machine to go where it's told. A properly built, properly operated machine WILL do this 100% of the time, whether using steppers or servos. A badly designed or improperly operated machine may, or may not, do this. "Closing the loop" on a badly designed machine, or one that is operated outside its limits, will NOT magically transform it into a good machine. EMC, apparently, will do true closed-loop control, at least with appropriate hardware. Regards, Ray L. |
| You have a couple of descriptions mixed in there. Steppers generally are never closed loop as there is no feedback device, servo's operate with a feedback device of some kind and close the loop via a PID method. With a system such as Mach where the control is through the parallel port, the loop is closed back to the servo drive, the loop is not closed back to the CNC controller (Mach). The controller sends a command and assumes that the position will be reached. With the addition of a motion card such as Galil, the control can close the loop back to the controller. This has the advantage of features such as electronic cam and electronic gearing, as well as true synchronized threading and helical milling etc. If you are also talking of DRO or scales on the final positioning, then dual feedback is required, an encoder on the motor and a scale on the final positioning device, the PID loop is then split between the two feedback devices. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Thanks to Ray and Hans for the responses. Ray, could you elaborate a little more, why e.g. backlash is still an issue with a closed loop system? From my understanding, backlash is a problem in the mechanical coupling of the driveshaft and the table. Assuming I am able to read the position of the table exactly (up to epsilon precision), how would the backlash still affect me? -Jan.
| Al, you are right, I wasn't particularly precise in my description. I am referring to a setup independent of the particularities of the drive mechanism. More abstractly, I am assuming that I have a means to measure the absolute position of the workpiece/table up to some precision, similar to a DRO. If I have this measurement available, can I not use this to control the drive mechanism? E.g.: the computer drives the X-axis until the measurement increased 5mil in value. -Jan.
| Yes, if you can measure the table position, you can use this to drive your motion control system, but your motion control system is probably going to be more sophisticated than the typical hobbyist mill. And you can use DROs as the sole encoder. For steppers you would need a motor driver that accepts encoder feedback and compensates for position error. Again, Copely Stepnet amps do this as an example (I've used them, but I don't like them). Practically any brushed dc motor servo amp could operate w/ a DRO as the sole feedback. A brushless DC servo amp can work well on just DROs if the BLDC's have hall sensors. If they don't have hall sensors, you'll need an amp that can perform hall-less commutation and a system without much backlash. Most modern digital BLDC amps can operate w/ encoder feedback only (no halls). I have worked with AMC digiflex and Copley Accelnet and Xenus amps in this way. |
| Some of the Galil on line instructional video's are worth checking out to get some precise idea of servo mechanisms in particular. There is one that deals with dual feedback to eliminate backlash as a last resort. http://www.galilmc.com/learning/tuto...sation-methods These video's, although geared to Galil, are common to most PID loop systems. Al.
Regards, Ray L. |
| Open Loop to Closed Loop Stepper Conversion | beamhome | Stepper Motors and Drives | 0 | 01-02-2008 12:41 PM |
| question on closed loop vs open loop (servo systems) | boonie | Servo Motors and Drives | 20 | 11-09-2007 01:30 PM |
| Closed loop vs. open loop | pelesl | Benchtop Machines | 10 | 04-06-2007 05:56 PM |
| Lathe conversion - open loop vs closed loop | bhowden | General Metal Working Machines | 7 | 03-21-2006 04:56 PM |
| Closed loop....open loop? | DAB_Design | General Electronics Discussion | 10 | 06-26-2004 05:02 PM |
