Page 1 of 5 1234 ... LastLast
Results 1 to 12 of 54
Thread: want a enclosure for my x3...
    Registered Teyber12's Avatar
    Jul 2008
    I really would like to build a nice enclosure by around Christmas time, so i can sell my box and pan brake and use that $ to invest in a real lathe.
    I was trying to design a good stand + complete enclosure for my x3 with a completely slanted bottum pan for coolant, and 1 bar to stiffin up the z axis so its just a little steadier while plunging with a large endmill into copper, at any speed. I quickly realized its going to be a LOT of work and will be very difficult to make, especially since the only welder i have is a oxygen acetylene torch...
    So what have you guys done? what do you guys recommend? i have seen lots of things that sit on top of a bench but i would love to have this off the workbench and in another corner of the garage.
    Cheers guys
    Gold Member hoss2006's Avatar
    Apr 2006
    Check out loadedagains for his IH, really sweet looking.
    A couple more designs in devincox's thread.
    just scale it down a tad for your X3.
    I thought Pete had some pics of his but I can't locate them.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Registered SpeedsCustom's Avatar
    Sep 2006
    I hope and think you will be pleased with my enclosure that I recently been working on. I started about 2 weeks ago actually revising my over one year old enclosure. With full heavy flood it leaked in certain spots, really annoying, but I hope all my new work I have done will pay off and keep it from leaking. I can't believe how long it took to finish, and it's actually not even done. I have spent almost the entire day just putting it back together.
    The the fun little stuff is going to be happening now with it. Making and installing my custom collet holders, little racking on the side for certain tools,installing pipe wort for coolant and air hoses. I have coolant through vinyl hoses but I was able to get a ton of stuff from grandmother's home in Brooklyn, that use to belong to my grandfather. So not only did I get all these tools that are useful in the shop, I got a lot of interesting things. Tons of outlets,switches, racks, roller clevis', files and two boxes worth of beutifully chromed piping and fittings that while totally unnecessary to use in the enclosure, since I have it. I will use it
    You will see all of the new work done tomorrow, I will be taking pics. I was going for a HAAS look
    -Jason
    Feb 2009
    Metal is great but expensive, try to find some scrap other than bedframe material. I found some scrap pallet rack material on Craigslist, one 8ft vertical section let me make the enclosure below. Cost $30.
    $25 more let me make the catch pan underneath out of thin gauge steel, don't remember the gauge but it bends by hand and is hard as hell to MIG weld because it was so thin. Makes me wish I DID have an OAG setup!
    Pix are before the drain hole, side walls, etc. I need to add a bar to the top for a counterweight. The casters were probably the most expensive thing, do a search on my posts (don't have many), there's a link in someone's thread. The plastic boxes were just to hold up the pan while making mounts (it's removable).
    If I were to do it again, I'd make the pan drain faster, I get a fair amount of standing coolant which ends up evaporating. I had not planned on flood or mist when I first made the pan. Coolant dripping from the machine into the pan also caused splashes, which when allowed to build up, creates a leak. I cured that by adding plastic sheeting in certain places.
    Might as well mention I'm using an HF dirty water submersible pump in housed in an $8 Walmart tall kitchen plastic garbage can. The pump needs 3" of fluid minimum to sit in. Works great, speed is controlled by an HF external router speed controller. Coolant drains from the pan down into a Chevy smallblock water neck I had laying around, through a radiator hose, into a sheet metal tray with holes drilled in the bottom and stuffed with stainless steel wire mesh scrubs. Oh, I cut the foot off one of my wife's nylon stockings and slipped that over the rad hose as a pre-filter. Can you tell I'm cheap???
    PS Car oil filter elements and home water purification filter cartridges make great filters, but are terrible at flow unless you pressurize the flow through it. Otherwise, it will just sit and you'll starve your coolant pump. Coffee filter might work also?
    Sep 2006
    Va va va very nice!
    I like the the Red.
    -Jason
    Aug 2004
    Rezcar,
    What are the dimensions of your enclosure.
    You wife probably turned around and spent $10 on a new pair of hose...
    Thanks,
    Paul
    Sep 2006
    Let me tell you what the best filter is: I have been using Humidifier pads from Home Depot for a few years now. Simply the best, I have a real amazing drainage system, but I don't have any chips in the tank EVER.
    -Jason
    Registered mwood3's Avatar
    Jun 2008
    Jason,
    Care to post pics? im interested in seeing your design...
    http://www.g0704.blogspot.com/
    Sep 2006
    In the first picture you will see this U channel I used that the coolant travels along. The key is to not have a great deal of pressure with coolant and chips, as in...There is only a small angle that the channel creates, enough for the coolant to flow at a good pace but not fall with gravity and chips like most conventional systems.
    The drain is a center drain and has a pre-filter, again a simple humidifier pad is use on top of the drain hole and piece of meal stock on top to keep pressure so that it contacts all it's surface area. When the coolant gets through and travels down the channel, it encounter two more filters before falling into the oil funnel which has a screen, that catches any little chip that get through the end.
    The coolant travels down a hose and spills on top of the container lid where gravity lets it fall through the cracks.
    In the last picture, notice the hose and wet area?
    Feb 2009
    Ha! I'm dreading the day I'll have to go buy new ones to replace the clogged one!
    Dims are:
    28" tall without caster
    36" deep
    48" wide
    The thinner surround frame is 40" tall
    Quote Originally Posted by ViperTX View Post
    Rezcar,
    Thanks,
    Paul
    Feb 2009
    Quote Originally Posted by SpeedsCustom View Post
    Very nice, I'm thinking of switching to a resovoir with a lid to slow down the evaporation.
    Any pix of the entire enclosure? From the bench, it looks as if it's flat bottomed?
    Feb 2009
    Also, what section are the humidifier pads found in at Home Depot?
  • Page 1 of 5 1234 ... LastLast
    1. What to use for an enclosure?
      By Tim Wiltse in forum Xylotex
      Last Post: 10-03-2008, 03:36 AM
    2. Another Enclosure : )
      By Rich05 in forum Industrial Hobbies (Support forum)
      Last Post: 06-12-2008, 08:45 PM
    3. tl 1 enclosure
      By fourperf in forum Haas Lathes
      Last Post: 02-25-2008, 05:56 AM
    4. My new enclosure
      By David Da Costa in forum Commercial CNC Wood Routers
      Last Post: 10-28-2006, 01:03 PM
    5. New All In One Enclosure
      By mlaws1172 in forum General Electronics Discussion
      Last Post: 10-20-2006, 08:26 PM
