Page 1 of 2 12 LastLast
Results 1 to 12 of 18
Thread: Newbie - Proxxon BFW 40 CNC conversion
    Oct 2009
    Italy
    Hi all. Just enrolled...
    I looked around but could not find any post about a Proxxon BFW 40 CNC conversion (you're already laughin...right?).
    I've been having this little mill for a while and since I found 4 stepper (Nema 23 1.8degree 200steps per revolution 116oz bipolar), I tough I could give it a try and have some fun on this project.
    I'm sure I can arrange the motor set up but I'm really concerned about the price for the driver (a gecko g540 would cost more then the mill...).
    I've seen several cheap driver on sale on eBay but I would not know how to choose the right one.
    Any suggestions ? How about the Power supply ?
    Thanks to all
    Sep 2003
    OK
    I would go with a controller like the Xylotex for a little one like that. I used that controller on a little X1 and have had no problems with it in about 5 years.
    hth
    Jeff
    Oct 2009
    Italy
    Thanks for answering.
    The Xylotex costs $410.00 and comes with motor. It would not be a saving.
    I believe that a system should be made of cost comparable items (like on audio, you would not spend $100 on speakers and $1000 on amplifier...).
    As I said, on eBay there are tons of driver for around $60.00. Is there any good ? What should I look for ?
    Gold Member hoss2006's Avatar
    Apr 2006
    Several Proxxon CNC conversions I've seen only need to use Nema 17 motors so a powerful driver is not needed.
    Kdntool only use 83 oz/in N17 on their Proxxon MF70 kit which looks like a bigger mill.
    Hobby CNC make a small DIY kit with motors for only $235 or you can just get the driver kit for $64.
    They have 4 axis boards too.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Sep 2003
    OK
    Unless Jeff change his parts lists you used to be able to buy the controller for
    about $90. I recommended that based on the size motors you said you had.
    The other one listed by Hoss is also a good choice for your size motors, but I think that one can only drive unipolar and I dont know which connection type
    your motors are.
    Jeff
    Oct 2009
    Italy
    I made a mistake about the motors I own: they are unipolar. See the pictures:
    Beside what is written on the label, as I said, I know they are Nema 23 1.8degree 200steps per revolution 116oz, 8 wires.
    I am trying to pinpoint the electronic I need, but being my first with stepper motors, bare with me.
    - The HobbyCNC PRO Driver Board Packages looks fine and a project that I can handle.
    1) I'm not sure witich package to choose, based on the voltage of my motors
    2) $250 + transformer is not really chip.
    - Xylotex sells with motors and he does not ship to Europe (?) so this is out of the way.
    - I've read that the G540 Gecko is a sure winner and probably a good buy for future upgrade but, looking at the manual, I've got rather confused. I am afraid of being stuck with a $299 thing that may require different motors and may be too difficult for me to hook up and hadle.
    3) is it too much for my project ?
    4) On eBay I found a Keling driver for $139 (1 pcs 6 axis breakout board, Built in Optical-Coupler. Surface-Mount + 3 pcs Bipolar Stepper Motor Driver, 40V, 3.0 A). Sounds like a bargain but will it fit ?
    http://cgi.ebay.it/Three-Axis-CNC-Ro...item3a4eec6286
    5) What about this Allen-Bradley driver?
    http://cgi.ebay.it/3-AXIS-CNC-ROUTER...item4ceb9d2529
    My god. There are so many at affordable prices. What whould I look for in term of specification that will fit with my motors?
    Thanks for any help
    Sep 2003
    OK
    Go with the hobby cnc board. Matches your motors well, and since this is your
    first jump into CNC you probably should stick with new gear that is well documented, it will save you a lot of time in the trouble shooting stage of the
    build.
    The power supply you could ebay or build yourself without to much pain, the case could be about anything. If i remember right the Hobby CNC board sells for about $80 for 3 axis.
    hth,
    Jeff
    Oct 2009
    Italy
    Thanks, I will do that.
    Should I get the
    3 Axis w/(3) 130oz-in 2.6V 2.1A
    or the
    3 Axis w/(3) 205oz-in 3V 3A ?
    Thanks for the help.
    Sep 2003
    OK
    Either would work fine, or you can just buy the Controller and use your motors your already have.
    Jeff
    Oct 2009
    Italy
    I'm bakc to step 1, since HobbyCNC does not sell the kit without motors.
    So I will have to buy the driver only. I just hope I can find a suitable power supply...
    Apr 2006
    Keling is still sold out of their cheaper 36v PS.
    Circuit Specialist have several to choose from, a 30V and a 24V.
    Hoss
    Oct 2009
    Italy
    Sorry, are you saying that the Circuit Specialist 30V or 24V are a good choice to be used with the HobbyCNC driver and my motors ?
    Wich one should I order ? 30V or 24V.
    After several days on the web I still can not tell how am I supposed to size the power supply, related to controller and motors....
    Thanks for any help
  • Page 1 of 2 12 LastLast
    1. Proxxon MF70 cnc conversion.
      By stenberg in forum Vertical Mill, Lathe Project Log
      Last Post: 03-06-2013, 10:50 AM
    2. PROXXON micromot conversion.....low cost
      By GERY in forum CNC Wood Router Project Log
      Last Post: 07-21-2010, 04:34 PM
    3. Newbie- Hi there Proxxon help
      By Dave Lister in forum Hobby Discussion
      Last Post: 04-26-2010, 12:51 AM
    4. Newbie Looking for Advice (Sherline or HF Conversion)
      By Deviant in forum Benchtop Machines
      Last Post: 09-26-2004, 09:10 PM
    5. Replies: 3
      Last Post: 08-22-2004, 09:06 AM
