  #13   Ban this user!
Old 10-27-2009, 06:16 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
There are some nice Fusion kit mods in this thread:
http://www.cnczone.com/forums/showthread.php?t=51611
CR.
  #14   Ban this user!
Old 10-27-2009, 08:47 PM
webgeek is on a distinguished road
So I can't cut mild steel on the X2? I don't plan on making the chips fly, I just wanted to cut out small 2.5d parts in general.
  #15   Ban this user!
Old 10-27-2009, 09:16 PM
Dougal is on a distinguished road
Who told you that?
I haven't tried slotting or surfacing mild steel in mine. But I've engraved heaps of stainless with a ball cutter.
I tried milling a hex into some 304 stainless bar when I got the mill running and it was chatter city. I haven't tried since I've put the back brace on but the mill is at least 5 times stiffer than it was.
My X2 CNC Brain Build: http://www.cnczone.com/forums/showthread.php?t=61345
Gecko G250 wiring errors: http://www.cnczone.com/forums/showthread.php?t=68960
  #16   Ban this user!
Old 10-27-2009, 09:43 PM
Yea torque is an essential spec when choosing a motor for a cnc.
most commercial machines use big 2HP motors that are supplied by 3 phase power.
If you plan on cutting steel plan on getting a decent sized motor.
That's what my comment was based on. I figured mild steel would be fine. I'm adding a back brace to the mill almost immediately so at least the most obvious weakness will be addressed.
Mike
  #17   Ban this user!
Old 10-27-2009, 10:12 PM
tumutbound's Avatar
tumutbound is on a distinguished road
Mike
The post from crestiksa refers to 2HP, 3 phase motors so it's a pretty safe bet, he's never seen an X2
Regards
Geoff
I need to review MBG General Metalwork Discussion 15 03-07-2008 02:57 PM
HF 8 X 12 review ???? Dan S Mini Lathe 1 09-08-2004 09:57 PM
