Old 10-12-2009, 11:07 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Exclamation White particle board?...
I really like working with white particle board when it comes to my shop. I have done some research on melamine. It does appear to be waterproof because it is a type of resin/plastic product.
I'm just asking for a second opinion because I need to use some inside my milling machine enclosure that runs full flood. And other than keeping the actual wood dry, i'm not concerned with it being submersed, cause it wont be. It will simply be getting splattered on.
Just thought I'd ask.
-Jason
Old 10-13-2009, 01:23 AM
HimyKabibble is on a distinguished road
The melamine surface itself is nearly indestructible, and impervious to most fluids you'd find in a shop, but you need to do something to seal all the seams, and make sure the melamine surface does not get damaged in any way - If coolant, or pretty much any liquid, gets into the particle board itself, it will disintegrate rapidly.
Regards,
Ray L.
Old 10-13-2009, 03:14 AM
tumutbound's Avatar
tumutbound is on a distinguished road
Also make sure your particle board is high moisture resistant (HMR).
This is a waterproof particle board intended for use in kitchens.
Regards
Geoff
Old 10-14-2009, 01:34 AM
muddobber76 is on a distinguished road
At the big hardware stores like Home Depot and Loews, you will find an iron-on edge banding that is made of pvc. Very inexpensive. I think this and silicone at any joints would make for a fairly water resistant rig.
Old 10-14-2009, 09:54 AM
Thanks guys, I don' think i'll be needing it really, I had plenty of stainless steel in the shop.
Thanks though,
-I'll use it somewhere though.
-Jason
Is white particle board waterproof? SpeedsCustom WoodWorking 4 12-14-2009 10:46 PM
Problem- MIL-C-13924 white powder? ghyman Metal Finishing and Plating 0 02-19-2008 04:28 PM
Copper is white? lloyd778 Casting Metals 2 02-08-2008 04:38 PM
Tool Gray or White? MrRage General Metal Working Machines 20 02-21-2006 12:01 AM
mdf and particle board ljoe1969 DIY-CNC Router Table Machines 3 07-21-2004 04:14 PM
