Old 10-12-2009, 01:39 PM
kawaput is on a distinguished road
Motor siezes up on Benchtop mill
Hello, I have a benchtop mill. Not sure what brand it is but it's made in India. The Y motor went back to far and pushed the bearing out of it's housing in back of the machine and siezed the motor up. I bought a new motor and installed it and that motor also siezes up. I think the problem might be in the board of the controller, it is a DSP Servo 511, but I'm not sure what to look for on the board, or where to buy a new board. We are running Mach 3 with it.
Old 10-12-2009, 01:50 PM
LongRat's Avatar
LongRat is on a distinguished road
Are you sure it is the motor? Can you run the new motor in free air? I would be suspicious that the bearing that was pushed out might be damaged, or the screw or nut may be out of alignment after the crash, causing binding.
Old 10-12-2009, 01:58 PM
Yes, the new motor siezes up in mid air.
Old 10-12-2009, 11:22 PM
AlbertaClipper is on a distinguished road
Did you see if a controller from one of the other axis seizes your new motor?
Tags
controller, dsp, servo, sieze
Looking to by CNC Benchtop mill vtracer Benchtop Machines 6 05-28-2008 06:33 PM
BenchTop Mill to Buy leeschaumberg Benchtop Machines 8 04-10-2007 05:57 PM
Has anyone seen this benchtop mill before ? jeff2005 Benchtop Machines 6 02-11-2007 10:46 AM
Not Exactly a Benchtop Mill dcprecision Benchtop Machines 11 09-28-2006 10:58 AM
