Old 10-12-2009, 06:02 AM
Chris85 is on a distinguished road
Want to build my first CNC machine :D
Hi all a complete newbie here...
Years ago I wanted to build myself a CNC machine for PCB as well as cutting some aluminium panel for project boxes. I built the alegro 3977 controller and my only 2 samples blows and that puts me off CNC building for a while along with other things.
So anyway I think Im gonna start the project again.
What I have right now is 3 stepper motors, spec is 1.8deg 2A 1.4NM. I also managed to buy more than enough L297 + L6203 from ebay very cheap. Designing/building the controller, breakout board and the PSU isnt a problem as I already have most of the parts from other projects.
I need something like 12" x 9" x 2" work area. Cutting/drilling/milling PCB as well as aluminium and plastic up to a thickness of 2-3mm.
Are the items below suitable for what I need >>>
20mm rail + linear bearing
12mm x 5mm ballscrew
120w spindle
I can live with slow machine as long as the work get done. Please advice
Cheers
Old 10-12-2009, 07:11 AM
It look like I posted in the wrong section
LOL
Old 10-12-2009, 07:34 AM
mwood3's Avatar
mwood3 is on a distinguished road
yup, looks like you should try the DIY CNC router section...
http://www.g0704.blogspot.com/
Old 10-12-2009, 08:14 AM
Yeah this place is probably the biggest forum on earth. But Ill read up some more, perhaps the answers to my questions are already out there. Lots of reading to do.
Cheers.
Old 10-16-2009, 01:41 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Chris. Welcome to the Zone!
Maybe reading some of this basic info will help you get started:
help with old parts
CR.
Need Help!- new machine build don_don Automation Technology Products 0 02-08-2009 12:39 PM
Need help to build my own CNC machine enixidfrag Laser Engraving & Cutting Machines 2 05-04-2008 05:22 AM
New Machine Build skipper_52 CNC Wood Router Project Log 8 04-07-2008 07:13 AM
Use the second machine to build the first! Madclicker CNC Wood Router Project Log 160 06-27-2007 12:29 AM
Want to build new machine thuffner3 CNC Machining Centers 2 02-14-2004 09:47 AM
