I made this Friday for my spindle on my X2 Milling machine. It started off as a square piece of stock and I did most of the work with my mill and rotary table. It consists of 18 ultra bright LED lights and they are glued in with 5 min epoxy. This replaces the old spindle cover and uses the same bolt holes to mount. Dale P. |
| "Do you work in the dark?" Not too often, but some times I blow a fuse. : ) I have lots of lights in the ceiling of the shop but the head of the machine casts a shadow on the vise and part that I'm machining so I'm hoping that this will help. I also wanted to take my new rotary table for a spin and see what it could do. I'm happy with the results and can't wait to use it again. Dale P. |
| I took apart a old phone charger for the power supply and installed it inside my control box. One of the switches turns it on and off. I built the control box a while back and added the extra switch for a future light. The LED lights require 3 to 3.5 volts @ 430 ma and the power supply puts out 5 volts @ 1000 ma. I had to add a small resistor to lower the voltage to prevent damage to the LED's. "I loved the movie Close Encounters of the Third Kind!" I should rent that again some day. Dale P. I know I have to add labels to the switches some day! |
#10
| "You really need to CNC that thing Then you could engrave your switch panel. Once you go CNC you'll never look back !" I already have one, but I'm not very good at writing G code and have a lot to learn. I hope to take a class on CAD very soon at the Tech. I just got my copy of Home Shop Machinist and someone wrote an article on building a spindle light for the X2 also! It was pretty neat to see one week after I built mine. Dale P. |
| a ring of 200 Led Lights to light up? light source render? | Rich05 | Solidworks | 6 | 10-25-2008 07:16 PM |
| Taig Spindle LED Light | fretsman | Taig Mills & Lathes | 3 | 06-21-2008 07:46 PM |
| WTB: Spindle motor for wood/plastic/light metal | DIY-Guy | Want To Buy...Need help! | 4 | 05-12-2008 04:06 AM |
| Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal | SCG11762 | General Metal Working Machines | 2 | 08-27-2007 09:08 AM |
| Spindle/e-stop/grn Light/brake Wiring | TPMX | Bridgeport and Hardinge Mills | 0 | 05-05-2007 09:46 PM |
