Old 10-04-2009, 10:45 PM
ZOB ZOB is offline
ZOB is on a distinguished road
Winter Project X2 CNC conversion
My winter project is to convert my X2 mill to CNC. I've spent hours reading thru the forum and have come up with list of items I need to order, but before I do I wanted to post and get the opinions of forum members.
I intend to get a rotary table in the future to make a 4th axis but For now Just getting the conversion done is the project.
From Keling
(4) KL23H2100-35-4B (1/4” Dual shaft with a flat) 381 oz-in $196.00
(1) G540 4 axis driver $289.00
(1) KL- 4813 Unregulated Power Supply 625W 48VDC/13A $129.00
and From CNC Fusion:
Mini-Mill CNC kit #4 - with X-Y w/BALLSCREWS $559
I already have MACH3.
Old 10-04-2009, 10:52 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
sounds like a winner. good choices.
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 10-05-2009, 12:26 AM
mwood3's Avatar
mwood3 is on a distinguished road
You got the thumbs up from Hoss on an X2 CNC conversion on your first shot, Nice job...your good to go :P
P.S. Just kidding with ya hoss, you da man as far as the X2 goes ^^
http://www.g0704.blogspot.com/
Old 10-05-2009, 01:08 PM
forrest39 is on a distinguished road
ZOB,
I'm planning something similar with an X2 soon. Two questions though,
Why did you pick the 381 oz-in steppers as oposed to the 387's?
Also, how did you pick that power supply? I'm thinking of the 7.3A KL-350-48 but perhaps there is a good reason to get a 13A supply?
Not being critical, just trying not the be penny smart and pound foolish.
Cheers!
-4ist
Old 10-05-2009, 01:50 PM
TXFred's Avatar
TXFred is on a distinguished road
I have a related question. Why an unregulated power supply? Is there an advantage?
Fred
Old 10-05-2009, 02:01 PM
escott76 is on a distinguished road
Originally Posted by forrest39 View Post
ZOB,
Cheers!
-4ist
Most likely because they are a better match for the driver stated. You'll get more out of the 381's with a G540 than the 387's at the limiting voltage of the G540.
Old 10-05-2009, 02:49 PM
escott76,
What in the data should point me to that conclusion? Comparing the two on the kelling site, the 381 has resistance of .73 and inductance of 2.8. The 387 has resistance of 1.0 and inductance of 4.1. Is that the difference?
the price is the same, but does the 6 oz-in difference is torque not conform to the 'bigger is better' theory?
For some reason I was under the impression that a larger voltage power supply would equate to more voltage output to the motors - gotta go back and look at that!!!
Thanks! -4ist
Old 10-05-2009, 04:29 PM
escott76,
Thanks! -4ist
a) Bigger isn't always better
b) It's primarily to do with the inductance number. You choose a supply voltage based on the inductance of the motor (32*sqrt(inductance)). The 387 wants a higher voltage than you can feed through the G540 to meet this rule, the 381 will do better on the same voltage. At the max voltage of the G540, the 381 will produce more torque.
Not to say at all that the 387 is a bad match for the G540, I currently run 4 of them on mine, but the 381's weren't available when I bought them, or I would have chosen them.
Old 10-05-2009, 08:24 PM
ZOB ZOB is offline
Thanks Hoss , I feel good about my choices if you agree, And thanks for the info on your site, I've enjoyed viewing it.
As for why I picked these items alot can be found here:
steppers for cnc fusion x2 conversion
As for an unregulated power supply, I don't know of an advantage other than price. I saw the KL-600-48 48V/12.5A $139.95 115V /230V But I was under the impression to avoid switching power supplies, can't remember where I heard this. Hopefully the others here can explain this.
Old 10-05-2009, 09:11 PM
HimyKabibble is on a distinguished road
The question should be: Is there any advantage to a regulated supply? And the answer is "No".
Regards,
Ray L.
  #11   Ban this user!
Old 10-06-2009, 02:52 AM
escott76,
Thanks! -4ist
Thanks for that formula and explaination.-4ist
  #12   Ban this user!
Old 10-09-2009, 06:07 PM
ZOB ZOB is offline
Placed orders to Keling and CNC Fusion today, The waiting begins....
Grizzly G0484 Conversion Project chiefsr Benchtop Machines 4 05-31-2009 01:04 AM
Build Thread- Clot's X2 conversion project Clot Benchtop Machines 11 01-07-2009 02:33 PM
Starting my winter project davef2f Benchtop Machines 2 11-05-2007 07:14 AM
Did you complete your winter project? WallCrawler CNCzone Club House 4 03-15-2004 08:22 PM
Engraver conversion project Alan T. DIY-CNC Router Table Machines 2 10-08-2003 08:23 PM
