#13
The 381 however, with it's lower inductance, WILL run a little faster. CR. |
#14
| Well I received packages from Keling and CnC Fusion. Everything arrived in good shape. I wired up my steppers and G540 ,cranked up mach3 loaded the road runner and the motors were spinning. I've read the Gecko file on heat sink tests, My Gecko got to 160 def F ( they had 180 f max ) So I will definitely get a fan on it after I build an enclosure , My steppers got up to 150 deg f . Is this normal? how hot can they get before damage occurs? I used 3.4k resistors and the steppers are rated for 3.5 amp. Will start installing the CnC Fusion kit next. |
#15
| Started Installing the CNC Fusion Kit , found a few challenges to tackle, the Y axis ball shaft would interfere with the base so I ground it a bit to obtain clearance, Easy enough. Also found that the X axis Lovejoy would interfere with the Y axis block , So I clearanced it also and now I have full travel on the X axis. I also Started modeling the X2 up since I have it tore apart, should prove handy when it comes to making up limit switch brackets later on. ![]() |
#16
| I remember when I installed the CNCFusion kit on my X2 I had to do a fair amount of grinding on the bottom of the X table but I don't think I had to do any on the Y. But I did have to grind the base for the Y ballscrew just like you did. Another thing you might think about is modifying the Y motor mount to provide more Y travel, it's easy and man, with out the extra travel I wouldn't be able to do much useful milling with mine. Great modeling work ! Last edited by SScnc; 11-08-2009 at 04:48 PM. |
#18
| To quote from the gecko FAQ: Q.) How hot is too hot for a step motor? A.) The maximum heat for most steppers is around 100ºC (212ºF), but it is generally never good to have the motor heat go above 85ºC (185ºF).
__________________ Regards Geoff |
#20
Mike |
| Grizzly G0484 Conversion Project | chiefsr | Benchtop Machines | 4 | 05-31-2009 12:04 AM |
| Build Thread- Clot's X2 conversion project | Clot | Benchtop Machines | 11 | 01-07-2009 01:33 PM |
| Starting my winter project | davef2f | Benchtop Machines | 2 | 11-05-2007 06:14 AM |
| Did you complete your winter project? | WallCrawler | CNCzone Club House | 4 | 03-15-2004 07:22 PM |
| Engraver conversion project | Alan T. | DIY-CNC Router Table Machines | 2 | 10-08-2003 07:23 PM |
