would using a timing belt instead of a worm gear work for a 4th axis that way you would have no gear backlash iam thinking of using 1-15 tooth xl pulley 1-60 tooth xl pulley 1/4 step on the stepper to get ratio of 1-4 that would give me .1125 deg. a step would that be good enough? |
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
That is almost certainly below the accuracy and resolution of the rest of the machine at that diameter.... |
| Sin(.1125) = X/0.75 You are solving for X which is the length of the side of the triangle that is on the outside of the circle .75 in radius. I get .00147 and some which means that at the diameter you describe you can move approximately 1 thou with every step. Sounds like enough to me. |
| What driver are you running? Is the microstepping adjustable? Hoss
| 1/8 microstepping would give you .05625 deg/step or .0007363108 arc length on the 1.5 OD. More than enough IMHO. Hoss
| Just check the following blog http://my-woodcarving.blogspot.com/
__________________ http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/ http://my-diysolarwind.blogspot.com/ |
#10
| A series of articles in the UK mag Model Engineer's Workshop recently described a CNC T&C grinder using a cascade of toothed belts to drive the cutter round from a stepper (to grind the flute teeth). By using more than one stage you can get a very high ratio, but the rigidity will be limited by the stretch in the final stage belt drive. Probably OK for grinding but maybe not for milling? John. |
#11
Here a site for my Timing Pulley Maker program. www.cad2gcode.com/pulley It also can be used for Indexing, to make any # sides. Bob A www.cad2gcode.com/freeprogram |
| Newbie- Gear or Timing Belt System for new CNC | CHESS IS GOOD | DIY-CNC Router Table Machines | 4 | 06-17-2008 02:56 PM |
| Need A Quote- Worm gear and worm drive | LEWENZ | Employment Opportunity | 3 | 04-27-2008 04:28 PM |
| timing belt for x axis | apex | Linear and Rotary Motion | 0 | 12-15-2007 08:06 PM |
| Changing Z-Axis Timing Belt on Boss 6 | snakebit95 | Bridgeport and Hardinge Mills | 4 | 09-10-2006 12:44 PM |
| Timing Belt for 10.5 foot travel axis? | DanOSB | Linear and Rotary Motion | 2 | 03-17-2006 12:50 PM |
