Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: X2 CNC Conversion questions
    Registered mwood3's Avatar
    Jun 2008
    I know that this same thing has been asked many times, but I would like to start my own thread to get all my info in one place, I am about to order an X2 and CNC it, I have a budget of about $1500.00 not including Tooling and the like...
    So my first question is this...If I bought an X2 from Harbor Freight $489.00, This CNCFusion Kit - Mini-Mill CNC kit #4 - with X-Y BALLSCREWS $559.00, and this kit from Keling - 6: CNC 3 Axis Package with 425 oz-in motor and KL-4030 Bipolar
    Driver with 36V /8.8A Power Supply: $379
    I also have the PC lined up with trial version of Mach 3
    What else would I need to get a basic system going?
    I know about the electronics enclosure, tooling, vise/workholding etc...I just need to know about mill specific stuff to get it running...
    http://www.g0704.blogspot.com/
    Oct 2007
    This would be a great way to start! Read the thread below.
    Planning an X2 conversion.
    Apr 2009
    The LMS tooling kit should get you all the basics you'll need. Then you can build from there.
    Jun 2008
    Thank you for your reply, however I have already read that thread, My main question was if the above mentioned kits can be considered complete in the sense that I will not have to buy anything else to get going? or will I need more? I really want to use Hoss mods to make an X2 Freak but I currently do not have another machine so I wanted to start with a kit that needed little to no machining to get up and running.
    Apr 2009
    Ah, I see. Must have misread. I too Kitted my CNC out. The Hobby CNC and CNC Fusion were easy and quick. I had mine up and running within a few days and did not need anything more than what was in the kits.
    Not a bad idea to start thinking about some sort of enclosure since those chips find their way everywhere. Also you may want to think about doing a belt drive/controller upgrade since that will only cost you under $200.
    As far as machine cost, I conned HF to use the 20% coupon and it only cost me $390! Give it a shot.
    Oh and have you verified proper function of your parallel port?
    Jun 2008
    As for the enclosure, I know what you mean...I am in charge of a CNC Machine shop with near 100 CNC Mills and Lathes...they all are full flood coolant/enclosure machines...but I do know the mess that can be made in a hurry...
    Tell me more about the belt drive/controller upgrade...are we talking about the spindle here?
    I do plan on using the coupon and I have a HF about 35 miles away from me...
    I already have Mach 3 on my PC but have no idea of how to check the Parallel port function...any tips would be appreciated...
    thx for your response
    Matt
    Apr 2009
    http://szabaga.com/x2/power/
    Copied from the old Harrison page.
    The used boards on eBay can be found for about $30. I used the factory controller box and everything fit well. Even re-used the factory wire. All you'll need is some female spade connectors and a little ingenuity. I noticed a large increase in torque and spindle speed.
    The belt drive goes without saying. Quiet, reliable, faster.
    Here is the monitor HobbyCNC recommended.
    http://www.geekhideout.com/parmon.shtml
    Gold Member hoss2006's Avatar
    Apr 2006
    Quote Originally Posted by mwood3 View Post
    Matt
    Put one of them to work and crank out a kit from the free plans.
    dxf's and stl's of the parts are available.
    the majority of the parts can be made manually on the mill and you can't get any cheaper than DIY.
    You can save enough to upgrade to the g540 keling kit.
    Keep in mind this is just the tip of the iceberg, If you stay interested in the hobby
    you are going to find LOTS of stuff down the road that you must have all of a sudden.
    Take your time, spend a little here, a little there, you'll have a complete workshop before you know it.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jun 2008
    Ok, I downloaded the parallel port monitor...what should I be looking for? I see I can Manipulate the settings, will this all be Driver specific?
    Jun 2008
    Unfortunately I do not get to "play" with the 400k toys hoss -.-, Toyota is a very strict company and even if I could each machine is set up to run 1 dedicated part over and over about one every 40 secs... 24 hrs a day... Work is just my learning tool and means to afford this hobby
    That being said, I plan on getting this first machine going, then using it to make a freak x2, enclosed flood coolant monster :O
    2 X2's are better than 1 :P
    and btw, there is tons of stuff I "just have to have" right now ...
    is the g540 keling kit worth the extra money in your opinion?
    Apr 2006
    I hear ya, wish I could get some CNC time at work but those pesky company jobs take priority.
    Can't let us have any fun.
    You can get more than adequate performance from the keling drivers, my videos show that,
    but the g540 is newer, faster and better.
    $200 better? that's your call.
    You don't HAVE to buy the best of everything to have fun.
    Hoss
    Jun 2008
    I do recall you mentioning something about a limited choice for micro stepping with the G540's would that have major disadvantages?
  • Page 1 of 2 12 LastLast
    1. X3 servo conversion questions
      By JB_in_Fla in forum Benchtop Machines
      Last Post: 04-18-2008, 01:06 PM
    2. Questions about 9X32 mill conversion
      By territorialmill in forum Vertical Mill, Lathe Project Log
      Last Post: 05-21-2007, 11:27 AM
    3. Questions about the IH Mill CNC Conversion
      By Bird_E in forum Industrial Hobbies (Support forum)
      Last Post: 05-15-2006, 12:11 PM
    4. CNC Conversion - Ballscrew Questions
      By Deviant in forum Benchtop Machines
      Last Post: 03-28-2005, 10:35 PM
    5. MM Conversion - Option questions.
      By Moondog in forum Benchtop Machines
      Last Post: 11-16-2004, 02:47 AM
