Results 1 to 3 of 3
Thread: Product Parting
    Registered eartaker's Avatar
    Jul 2009
    USA, Tacoma, WA
    Product Parting
    What is the preferred method to finish cutting a piece from the stock? every time I try I do not get a pleasant result I get a .010 jagged burn of aluminum all the way around the bottom of my piece. any ideas?
    Nov 2005
    mount it to a sacrificial surface (aluminum/plastic is what I have used in the past), and cut deep enough so you don't have the burr. make sure you are holding the part down somehow (if the part has bolt holes, it makes it very easy to hold, just takes some planning when you are programming the cnc)
    FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
    Dec 2008
    You've got to give a few more details to get a better answer. But a burr on the edge of the stock may just be an inevitable part of the operation. We've got a whole room and several employees at work who's only job is to clean up burrs. A file, and a deburring tool work wonders.
  1. Parting off help
    By 545Kurt in forum Mini Lathe
    Last Post: 03-25-2009, 09:29 AM
  2. Parting 6061
    By ozzie34231 in forum General Metalwork Discussion
    Last Post: 06-27-2005, 01:04 PM
  3. what up with the parting?
    By balsaman in forum General Metal Working Machines
    Last Post: 06-04-2004, 11:17 AM
