Old 02-27-2005, 12:16 PM
maxxdog21 is on a distinguished road
Z axis backlash
I just noticed that when I engage the fine adjust on the Z axis, the knob turns over one full turn before the head starts to move. I would like to get rid of this "slop". Does anyone have any ideas? I was thinking that I could put a shim behind the "rack" that is mounted on the column. This would move it out and make it tighter on the "pinion". Am I on the right track with this thought? And help would be great!
Old 02-27-2005, 03:52 PM
The Update
I put a .009 shim behind the rack and it helped a little. When I took the fine control off the machine, I found a worm and worm/gear setup. It seems that quite a bit of the slop is coming from this assembly. Is there a way to tighten this up?
Old 03-01-2005, 10:12 PM
MNoble is on a distinguished road
Sloppy Rack
I too was trying to figure a good way to limit the slop in the rack. After reading a few other folks attempts at this i decided to scrap it all together. I removed the rack, gear, handle and fine adj. I then got on ebay and started looking to ball screws. I found a 14" ground with nut for something like 40 bucks. I then machined a couple bearing blocks mounted them to the side of the column and it it working very well. I am pleased with it. Now the Stepper is mounted on the top of them machine and not stichin out the front.
Mike
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
Backlash with worm drives ? andy_ck87028 Mechanical Calculations/Engineering Design 9 02-02-2005 04:40 AM
Backlash comp: does other axis pause during? lesd General CNC (Mill and Lathe) Control Software (NC) 6 11-30-2004 01:05 PM
Z axis backlash adjustment help sieg x3 replicapro Benchtop Machines 0 11-07-2004 12:13 PM
