Hi everyone, just joined. Recently I became interested in CNC machines (Mills particularly) and as a result I decided to look around the web to see if I could find a good, affordable one (~$1,500). Unfortunately, I have had little luck. I was hoping that someone with more experience in this field could help me out. What Brand/Model of CNC mill would I be able to get with the following: 3 Axis At least 2' x 2' milling area (X & Y) About $1,500 If there are any with those specs for that price out there at all. Thank you very much for your time. |
| A mill, of the bed or knee type isn't going to be found in those kind of travels for that kind of price. Travels large and square like that are usually found in something more like a router, or a gantry or bridge mill. Even a router is going to be tight in $1500. What are you trying to cut, and what kind of cuts are you planning to make? Simpler 2D shapes, or complex 3D contours? What kind of material, foam, aluminum, stainless steel? The harder the material the more you need in a spindle, and that will cost a lot. Desktop mills (just the mill, no electrics or computer) are generally going to have significantly smaller travels than listed. Just for reference, the bridgeport and machining center I use at work don't hit 24"x24", cost a lot more than $1500 each, and won't fit in the average house. |
| I know 2'x2' doesn't sound like a lot, but it's a long distance to keep tolerances of a couple of thou over, and that costs. |
| Hmm, well I suppose I could step out of my price box a little here. I would much rather do that than have to scrounge for things. I've had my dose of that for this year working on my 3D printer. Thanks for your input I'll look around. |
Regards, Ray L. |
Regards, Ray L. |
| match 3 , powermill y 4 eje | Diegone | Spanish CNCzone | 0 | 04-18-2009 06:03 PM |
| H&T don't match? | Donkey Hotey | Haas Mills | 37 | 03-23-2008 08:30 PM |
| X1 and X2 mix and match | acondit | Benchtop Machines | 14 | 12-05-2005 03:11 AM |
| mix and match bds biipolar,unipolar | sailinon | Stepper Motors and Drives | 0 | 10-23-2005 04:54 PM |
| Can you mix and match ballscrew nuts? | sendkeys | General Metal Working Machines | 2 | 08-13-2004 07:14 AM |
