Old 07-25-2009, 12:09 AM
jlerion is on a distinguished road
X3 Conversion - saddle pins
Hello all,
I've just started the cnc conversion of my x3 mill (Grizzly 0619) using the cncfusion #4 kit. I have the table and the x-saddle removed, and have also removed the x and y lead-screw brackets. Now I see that there are two pins on the x axis-saddle. How does one remove these?
As you can see it didn't take me very long to run into trouble... any help is greatly appreciated,
Jack
Old 07-25-2009, 12:42 AM
Toymanf is on a distinguished road
From my recollection, these are tapered pins. Try tapping them thru lightly.
I hope this helps.
Frank
Old 07-25-2009, 01:03 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Jlerion,
This is a very good reference.
http://www.arceurotrade.co.uk/projec...on%20Guide.pdf
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 07-25-2009, 11:28 AM
Frank,
Yes, they are indeed tapered pins - and with a few gentle, but firm, taps from the top they did fall out.
In regards to Jeff's link - the indepth guide doesn't remove the x/y lead-screw blocks - strange though, because Mr. Watson does remove everything else - on the mill I mean.
Thanks,
Jack
Old 07-25-2009, 11:44 AM
jalessi's Avatar
Post
Jack,
Sorry, I should have checked for the x/y lead-screw blocks removal instructions.
Jeff...
Need Help!- Resurface X-table saddle with turcite eng101 General Metal Working Machines 1 05-23-2009 02:17 AM
X2 table/saddle/gib alignment sansbury Benchtop Machines 4 12-06-2008 03:27 AM
How do I cut my mill base/saddle? cnczoner Benchtop Machines 9 10-09-2008 05:13 AM
Wanted: Bridgeport Mill Saddle Sam Wilson Want To Buy...Need help! 0 01-21-2008 06:22 PM
How to stiffen up the saddle on a mini lathe? lucmorton Mini Lathe 2 05-21-2007 07:37 AM
