Old 06-13-2009, 11:17 PM
slashmaster is on a distinguished road
Can Watr jet cutting and laser cutting make endmills obsolete?
I'm starting to wonder if I could waste too much time and money learning about and collecting endmills, drill bits and collets when Lasers or water jets might be able to do the same thing better without tool changes? Can some other technology ever make endmills obsolete?
Old 06-13-2009, 11:46 PM
Water jet cutters and lasers can do some amazing things but I think the prospect that they could ever totally replace milling is practically zero. They supplement milling for operations where either their speed is a great advantage which is the case with laser in some instances, or their ability to cut very hard materials without introducing stresses or heat affected zones around the cut area as is the case for (abrasive) water jets.
Neither of these techniques can approach the precision possible with milling, they cannot do blind holes or slots and I cannot imagine how you would ever do a complex three dimensional shape with either of them.
About the only technology that could conceivably make end mills obsolete would be some form of EDM that was hundreds of times faster than current EDM and I think that is very unlikely.
Old 06-14-2009, 01:00 AM
the4thseal is on a distinguished road
they solve different needs, there is overlap, but nothing can be everything to everyone.
Old 06-14-2009, 02:13 AM
nlancaster is on a distinguished road
3d cutting anyone. I would so love a Waterjet for making custom case parts because they are mostly flat stock, and that is where a waterjet or laser excel. But they are starting to make 5-axis waterjets that can do some amazing stuff.
Old 06-14-2009, 03:07 AM
I did not say not not cool. i just wish it was not sooooo expensive. i wish they made a less expensive or smaller one...2x4 feet. nice vid.
Old 06-14-2009, 06:25 AM
serriadh is on a distinguished road
I'd imagine that "one day" lasers might be able to replace endmills; carefully controlled laser pulses could conceivably be used to cut blind holes: assuming you had very precise control over beam focus, each pulse could ablate a volume of material of predictable size. Presumably a suitable measuring system would be able to measure the depth of blind holes if such precise control is impractical in the short term.
You'd also be able to do things like complex internal shapes restricted only by your ability to insert mirrors or lenses into a part's interior during the cutting process.
This is all pie in the sky though. I'd anticipate flying cars and laser battleships first.
I don't think you could ever make waterjets either a) small enough to be used on non-industrial scales or b) versatile enough to cut blind holes. I'm open to being corrected on (a), but I think (b) is just something outside of the technology's capabilities.
Old 06-14-2009, 10:18 AM
kweierbach is on a distinguished road
One thing I learned don't say it "is just something outside of the technology's capabilities." Somebody will someday come up with a way to do it. Look how far technology has come in the last 30yrs just think where it will be in the next 30yrs
Kevin
Old 06-14-2009, 11:53 AM
escott76 is on a distinguished road
Every tech has it's place. Think about what you are asking though. Laser and AWJ can't even sub for each other all of the time. Each process in the production of an item has it's tradeoffs. One process will generally be the most efficient at getting a job done. For example, we have a pair of lasers where I work. For certain parts there is no way you could reasonably do them any other way. Then again, we also have a turret press that sometimes can do the same job cheaper.
Laser has a HAZ, and all sorts of other requirements that may make it impossible to use within a given job. It can't cut certain materials (depends on the material and the laser in question as well as many other operating factors). That being said, for what it works on it does a great job and it does it fast.
You've already got SLS (selective laser sintering) for 3D parts as well, but it will take a while to get it down to the level of a fast mill in terms of speed and overall cost. I'm not saying never, but it's gonna take a while, and in that time milling tech improves as well.
The right tool for the right job, given where we are in technology. There is still a need for a lathe even though a CNC mill can cut a circular part.
Old 06-14-2009, 01:23 PM
Kevin
Man, if I had anything of any value, I'd place money on water jet cutting being as likely to end up compact, versatile and able to make blind holes being as bandsaw technology making the same improvements
The physics of a water jet pretty much preclude it from whole areas of machining, not unlike a wire-EDM system. I can see it getting more powerful, more capable, smaller, cheaper, but drastically expanding its capabilities? Ceramic endmills, ultra-precise laser and plasma machining, high speed EDM, cheap ECM... these things seem to be natural evolutions of todays' technology. I don't think we'll see any surprises either way; today's machining processes are improvements on methods fifty years old, at the minimum. You're more likely to see new ways of assembling materials than shaping them after the fact, at this point.
Anyway, these opinions are worth exacly what you paid for them, and possibly less
Old 06-14-2009, 04:14 PM
philbur is on a distinguished road
People where using endmills 30 years ago and they are still using them today, where's the advance.
30 years ago I had a small manual lathe sitting on a bench, it's still there and I'm still using it.
Nothing wrong with dreaming, but holding your breath can be fatal.
Phil
Kevin
  #11   Ban this user!
Old 06-14-2009, 05:33 PM
Originally Posted by philbur View Post
People where using endmills 30 years ago and they are still using them today, where's the advance.....
Phil
In some cases radically different flute/helix geometry, carbides with an impact resistance and coatings that were not even dreamed about 30 years ago.
  #12   Ban this user!
Old 06-14-2009, 06:09 PM
Farasien is on a distinguished road
Depends...
Can a laser or waterjet cut a non-through pocket or journal out of a solid piece of something? I'd say until they can do that, at the same or greater speed (because time = $) and/or energy cost as lathes or mills, the answer is no.
-Farasien
Endmills for cutting splines laka General Metalwork Discussion 5 04-06-2009 08:20 AM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
Need Help!- how to convert a 3d file to a series of plane to make a CNC laser cutting? zaheer0047 Laser Engraving & Cutting Machines 5 10-12-2008 01:16 AM
Feed rate? Slot cutting with 0.031" endmills? Donkey Hotey Haas Mills 5 03-27-2008 01:24 PM
How to make gaps or cut outs in lines for laser cutting in corel draw or rhino niklasn78 Laser Engraving & Cutting Machines 18 08-14-2007 08:47 AM
