| New build - base on SX1L or X3? hi all, Im considering a new CNC build (I have a Proxxon MF70 based conversion). I want something a little larger, I have a honking big manual mill (11"x49" TOS) so somewhere between the 2. I think the travels on the X3 are about what Im looking for (~5.5"x14"). However the Super X1L is not far short in the travels dept (~1.2" in the X and a shorter Z), and is considerably cheaper. (approx 1/3 price) Given that Im going to CNC it, and hence effectively the mill is a kit of approximately correct shaped castings is there a good (£400) reason to choose the X3 as a starting point? (there will of course be more questions once I start )cheers Dave |
| Yes, its rigidity. I have an X2 and neither an X1 or X3, so I am reporting what I have read not what I know. I believe the X3 has a better spindle setup as well as a more rigid column than the X1. But ultimately its your money, and your choice. Alan
__________________ http://www.alansmachineworks.com |
| I have an X3. It originally got 16"x, 5 3/4"y and 14 3/4"z. I cut material off the table endplates so now I get 20 1/2"x and could easily get another 1/2" of z if I jack up the electronics cover on back. This mill has reverse so you can tap threads too, I don't know if a sx1l is like that. You have me confused, you say you have a small mill and a honking big 11" by 49" manual mill already right? Why would you ever need another? Why not just cnc your big mill. |
| Ok, maybe small is a bit to large a word for the proxxon, Travel is 134 mm (x axis), 46 mm on the y axis, Z (height) 80 mm. so tiny might be better. It is my first foray into CNC, and its easy to find space for it. unfortunatly it is really to small for the next project I have, and although I could do it on the manual mill I think it would be a good CNC job (identical sets of bits for an engine, eg 4 con rods) I dont really want to CNC my big mill, I quite like using it and it would need a lot of work (big heavy bits, very large motors etc). Theres always a need for another machine ![]() guess I need to look in the flesh at the machines, I thought the X3 column was mostly a sheet metal part that didnt really add anything. Dave |
| I have a pic on my mill comparison page that could give slash an idea of what you have now. A Proxon on a kneemill. ![]() The X3 would make a good intermediate. Hoss
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
Alan
| Hoss, funny what turns up, thats actually my proxxon on my TOS FNK25 ![]() Had a quick look at an X3 this evening, yep its quite a bit beefier than an X1 in the column area, and also the table/saddle looks stronger. guess I need to get a larger budget approval from SWMBO ![]() Dave |
| No kidding? That's funny, I saw that pic on the Home Shop Machinist forum a long time ago. ![]() Small world. Hoss
By the way, looks like you already have great equipment now! Are you starting a mill collection or something? Is the TOS FNK25 really your dads and he would be pissed if you cnc it? Or is it worth a lot as an antique and you don't want to mutilate it by drilling holes in it for steppers? |
#10
| nope, it really is mine. Its not an antique (well 1988), and it *could* be CNC'd I guess, but not this time (Its to heavy to move around and its set into a corner so it doesnt eat *all* the workshop space. ) A picture of my workshop: ![]() Behind me is a wall and a surface grinder TIG set and 'dirty work area'. A bit of background: A couple of years ago I was making a lot of small parts for sub micro helicopters (about 15mmx5mmx1.6mm) using the TOS. I decided that this was a bit silly and the proxxon would fit the bill better for tiny parts (20K spindle for a start), but it took longer to convert than intended, and now I dont make those parts any more. Now the Proxxon is ok for tiny, but the next project lined up is a 999cc 4pot turbo, and I need to do some engine sized bits (crank, conrods etc). I could do them on the TOS, but any excuse to get a new toy The TOS is a nice to use manual machine, and for one offs and such it saves having to draw/gcode things. Its also a Knee mill, and as such I think Id need to have both the quill and the knee cnc'd, which when you add a RT means 5 (4 stonking big) drivers. So as a relative noob to the CNC world I figured a larger useful benchtop size machine to play and learn on would be a good thing. (cheaper crashes )Having seen a lot of X series conversions that seems like a good place to start, knowledge available already. I think that I might roller nut all the axis (trying to do this on a budget, but if I have to remake the stock nuts anyway...) and generally consider the mill as a shipped together kit that needs assembling... cheers Dave |
#11
| Interesting shop. That mill looked a lot older than 88. Is the Lathe the same vintage? Why would you cnc the knee and the quil? I've never heard of anyone doing that. An X3 also has a quil ya know. |
#12
| Lathe is about 1955 vintage, Harrison L5 Quill has only about 5" of travel, whereas the knee has more, I assumed that you would CNC all the moving functions. I am a begginer at this. For a benchtop mill Id only do the head I think, as the quill is not very rigid when out and unlocked? And the Quill and head move together anyway. The TOS quill is, but thats a monster industrial mill. Dave |
| base cnc | zambrano | Spanish CNCzone | 0 | 05-07-2009 07:13 PM |
| 15M ram Parity (base 0) | Stu00 | Fanuc | 2 | 10-29-2007 10:49 AM |
| An IH build, base to table | ozzie34231 | Industrial Hobbies (Support forum) | 6 | 05-31-2007 06:05 PM |
| Is the base of the x3 a problem? | phantomcow2 | Benchtop Machines | 2 | 05-28-2006 11:11 PM |
