Old 06-07-2009, 11:13 AM
BSawyer486 is on a distinguished road
Question Servo for Spindle
Hey everyone,
Dont post much here so if I did this in the wrong place I appologize but read alot and thanks to everyone for teaching me what I have learned here.
I have spent way too much on my HF44991 (could have bought a small built machining center)...lol. I built using one of those argord treadmill motors (hundreds available when I bought mine) for my spindle, MC-60 board with C-6 to control it. Now it seems everyone is using them for windmills or something cause I cant find one anywhere. My problem is now my spindle bearings burned up and that got my motor WAY hot before I noticed.
I was wondering if anyone has been able to or is it possible to run a servo motor for the spindle and control it thru Mach3. I want to be able to spin a 1-1/2" or 2" face mill and maybe push a 5/8" spade or inserted drill thru aluminum. I dont mind spending a little money to do it as long as I can still afford my internet connection to get on here to thank you all.
Any help would be appreciated.
Thanks in advance,
Bruce
Old 06-07-2009, 11:22 AM
Al_The_Man's Avatar
It is possible with a DC motor and one of the KB or Baldor SCR drives, they have analogue input so you would need one of the PWM to analogue convertors used for Mach and VFD's.
If you get a motor with a tach on, the KB's etc use tach feedback for tight control.
Old 06-07-2009, 11:34 AM
Thanks Al,
Is there a way to explain to a simple guy like me how to calculate the required torque or I guess motor specs to have the strength to do what I am wanting to do. I have over built the column to base support so that's not too much of an issue but it aint rock solid like the big boys I run at work.
Thanks again
Bruce
Old 06-07-2009, 07:16 PM
Ok, I'll ask in a different way. Is there a known minimum oz in for using a servo to turn a face mill or drill. Hope someone can offer some help.
Bruce
Old 06-07-2009, 07:26 PM
Al_The_Man's Avatar
Send me a email adress via PM and I can send program.
Servo used spindle? Jonne Mach Lathe 4 07-11-2009 02:47 AM
Servo Motor for Spindle dneisler Gecko Drives 9 06-16-2008 11:25 PM
AC Spindle Servo Unit HELP Darkos Fanuc 0 10-31-2006 12:05 PM
Servo Motor Spindle BobWarfield General Metal Working Machines 12 09-29-2006 11:14 AM
dc servo spindle anyone? jed102 General Metalwork Discussion 4 09-13-2006 10:06 PM
