Old 06-06-2009, 09:23 PM
slashmaster is on a distinguished road
Anyone else have problems with an unbalanced crank wheel turning from vibration?
The handle for the Y crank on my X3 keeps vibrating to the bottom of rotation because it doesn't have a balance weight on the other side. Guess that means I must mutilate the machine some more and drill and tap a hole for a counterweight bolt?
Old 06-06-2009, 09:31 PM
MrWild is on a distinguished road
No, this means you need to use your gib locks. If you really want it balanced (which wont fix a movement problem) use stick on auto wheel weights on the back side of the handle. No need for mutilation.
Crazy vibration turning pipe tyler774 General Metalwork Discussion 8 06-10-2008 06:57 AM
Vibration turning between centers Jedi General Metal Working Machines 3 04-08-2007 01:26 PM
Turning A Grinding Wheel drill Mazak, Mitsubishi, Mazatrol 4 02-06-2006 08:24 PM
will this help with vibration problems? KEYTEEM Mechanical Calculations/Engineering Design 0 12-26-2005 09:45 AM
Too much wheel turning before bed begans to travel Vogavt General Metalwork Discussion 2 11-04-2005 06:28 PM
