  #25   Ban this user!
Old 06-30-2009, 02:10 PM
Waldermac is on a distinguished road
Thanks again
Ok I think I got it now.
On the Gecko G540 manual, in the suggested wiring diagram, it specifies a Relay power supply with two dc relay coils. Do I need that? What is that for? They connect to pins 5 and 6.
Will pins 7,8, and 9 if connected to my X2 motor control actually control my spindle speed with mach 3? I think I asked this already but didn't get any clear answers.
  #26   Ban this user!
Old 06-30-2009, 02:47 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
The relay's are optional, they could be used to control a coolant pump or a simple enable/disable spindle motor etc...
You may be able to use the VFD output for your X2, the Gecko VFD connection would take the place of the potentiometer on the X2.
I am not sure which one of the wires on the pot is the output though.
The attached video is informative.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  #27   Ban this user!
Old 07-04-2009, 09:56 PM
Well I got all the motors turning fine in mach3. I used the G540 presets. Has the steps at 20000 and they seem to turn pretty slow. Anyone know the ideal settings for the 387 motors with the cnc fusion ballscrew upgades. I'm referring here to steps, velocity, acceleration under the motor tuning page.
Micro-Mark Microlux 7x14 Mini Lathe Jaime128 Mini Lathe 120 06-01-2010 10:22 PM
Coming Down to the Taig Micro Mill or Grizzly Mini Mill. SpeedsCustom Taig Mills & Lathes 15 01-22-2009 11:14 PM
CNC for mini-lathe by SIEG (Micro-mark, HF, etc) JohnELMDAS Mini Lathe 7 01-23-2008 07:07 PM
suggestions for micro mill Hawkeye21 Benchtop Machines 5 01-11-2008 06:45 PM
Micro Mark Mini mill converstion CNCadmin Vertical Mill, Lathe Project Log 29 02-07-2005 09:27 PM
