Has anyone rigged up a remote alert to let them know when the machine is done or when it wants a tool change? I was thinking that I could use one of the commands that actuates a relay to trigger a micro controller that will sent a signal to an RF pager of some kind? |
| It should be possible to have it use the computers modem to call you on your cell phone. It is beyond my meager computer skills, but it should be doable. If you are in close proximity to the machine, say in the back yard working on the Honey do list, have it key a small frs or walkie talkie and you are all set. You could have it just activate a solenoid that pushes the talk button and also makes a noise or something so that you can tell it is your machine and not your wife. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
Good thinking TotallyRc! |
| I loved the idea someone over at the Mach 3 forum came up with. He basically said to have a phone mounted to the table and have the cutter go over to the phone and puch the buttons and call yourself. ![]() I'm thinking if you're using coolant, it may not be the best idea ![]() Dave
__________________ Dave->.. http://tinyurl.com/DLAManufacturing |
| 5artist5 My wife has been using an XCam2 wireless cam to an old "junker" TV for monitoring kiln temperatures. Cheap on eBay and I bet you've got an old TV lying about. That way you still get full screen on your videos! ![]() Cheers - Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| I sometimes watch it in a dark room all by my self. Mike
#10
#11
| Ok I have the Walkie Talkie ready to go and I started looking at the G540 and Mach# as far as how to set up the output to the relay and I want to make sure I have it right. So If I Go to Spindle Setup in Mach3 and enable relays and set M8 Flood Output to #3. Then in Output Signals I enable Output#3 and set it to Port1 Pin1. I should be getting a short to ground from position 6 on the G540 main terminal block? Also because my power supply is 48V I am guessing I need to use a 48V relay? Please let me know If I am on the right track here. |
#12
Mike
| Noob Alert or Run while you still can! | anoah | DIY-CNC Router Table Machines | 11 | 05-10-2003 09:15 AM |
